1986 firebird radio dying....
Old May 16, 2008 | 11:06 PM
Jammin'Trey's Avatar
Hey guys I have a delco radio out of my 86 firebird base model that is dying.
My left rear speaker has not signal/power going to it. I have plugged a good test speaker and even another good speaker to make sure it wasnt a bad speaker. All of the other speakers work except the passengers side rear 6x9.
Is there any way to fix the head-unit that is causing this problem. The front speakers both work (R to L fader changes between the two As does Front to Back fader for ft. to rear.)
Or should I just get a new head unit and adapter plate? I would like to keep it stock though.
Thanks, Trey.
Old May 17, 2008 | 02:01 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Re: 1986 firebird radio dying....
probably not....the way ur explaining it sounds as if the rear left channel has has burnt out. if u wanna keep it an original delco then ur best bet is to get one from the junkyard because the dealer will charge you an arm and a leg.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
arod231
Aug 16, 2015 02:51 PM
