Sub in the "glove box"
Old May 29, 2008 | 03:33 PM
jonathanryder's Avatar
I've got a Pioneer head, 6x9's in the sail panels, 5x5's in the dash, and 5x5's in the door's. Everthing looks totally stock, so I'm looking to keep it that way. I'm thinking of glassing up the locking glove box the the hatch area to stiffen it up, and put a single 10" sub in there. Recommendations for/against?
Old May 29, 2008 | 05:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: Sub in the "glove box"
to get the best performance out of a speaker the volume of the box needs to match the requirements for the speaker.
glove boxes are small and chances are won't give enough volume in the box to work with the lower frequencies and instead you are get more of peaky speaker that is tuned to a higher frequency
Old May 29, 2008 | 07:05 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You have quite a bit of area in there, and even more on the side with the spare tire. You can build a pretty stealthy sealed enclosure for either side and get some very nice sound out of it. JL offers a stealth box for the 4th gen cars and if I do recall someone was making them for our 3rd gen's. I've personally listened to the W3 in a 4th gen Trans Am and it sounds killer, I say go for it. Most modern 10's will work in as little as .5 cubic feet of air space so you should be ok on that front.
Old May 31, 2008 | 10:57 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i would say that your best bet is either an 8" Kicker L7 (they sound awesome) or if you are a little bit more crammed for space, check out the comp VT series. although they cannot handle alot of power, they have a VERY shallow mounting depth and small box size requirements.
Old May 31, 2008 | 11:20 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Old Jun 1, 2008 | 08:43 PM
Old Jun 1, 2008 | 08:46 PM
Brilliant!! Thanks much guys.
Old Jun 5, 2008 | 02:30 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
wait how do you fit a spare tire in teh glove box?
Casey Meyers
Mar 2, 2016 10:46 AM
88gta3508
Aug 29, 2015 08:25 PM
Blue92
May 17, 2003 07:04 AM
CamarosRUS
Nov 25, 2001 10:31 AM
3.1EyeCandy
Sep 26, 2001 10:44 PM
