dash speaker question
Old Jul 6, 2008 | 06:32 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
well i got two questions. my 82 t/a does not have dash speakers in it, there are the cutouts but no wiring or screw holes were ones should be how hard is it to run the wires just a pos and neg from speakers down to head unit? also what size are those speakers i cant remember. i also need to find a better way to hold down the dash speaker covers because whenever i am playin hard when i hit second the cover flys off and hits me in the face lol. thanks
Old Jul 6, 2008 | 08:58 PM
blue91z28cam's Avatar
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Re: dash speaker question
Im no expert but I installed a pair of 4x6's under the dash pad..I have a camaro so Im not exactly sure if TA's are different....
the original wiring from the stereo have a "special" connection at the end where the speaker is connected but if you say that you dont have any wires at all I dont see why you cant just run +/- wires down to the unit..unless there is also another "special" connection behind the radio pod...
Old Jul 6, 2008 | 09:22 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Not sure if it will help you at all, but when wiring up my dads cd player in his 86 monte SS, I used a metal coat hanger and bent it to find its way to where i could run some speaker wire and then bent a loop in the hanger, stuck the wire in and pulled it up through, worked flawlessly for me.
Old Jul 6, 2008 | 09:40 PM
Screamin86's Avatar
im not too worried right now about adding the dash speakers atleast i got some tunes to listen to for now idk how well ill be able to hear it cause of my exhaust but we'll see.ill look around a lil more and see if i find any wires. i had a heck of a time wireing the radio up since the guy before had cut the plugs off and then had the head unit stolen later down the road so it was all kinda pulled and torn up
thanks 885speed ill try that
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
89lsc
Aug 14, 2015 04:58 PM
