tweeters in a-pillar
Old Jul 10, 2008 | 04:24 PM
MY87T/A's Avatar
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
I understand all the sound imagery, i have built tuned sub enclosures too. The tweeters are satalite and can be turned in there mounting pod. My question is... I have a 5" tach mounted right over there on the driver side a pillar. What is the max height i should go on the tweeters to get accuarte sound? I have Rockford 6x9's in the back and pioneer 4x6's upfront. And a single vented audiobahn 10 in the back area. The Sound IS set GREAT!!! the problem is my front speakers don't have enough high's in them and i have tweeters to put in. My dads truck we did the audio with tweeters on his a-pillar and couldnt be happier. Thanks Jake
Old Jul 10, 2008 | 11:51 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: tweeters in a-pillar
I have a set in my ride installed near the top at about ear level when sitting in the car. Not a specific scientific answer but it works great for me.
Old Jul 14, 2008 | 06:27 PM
MY87T/A's Avatar
Engine: 355 SBC
Do you have any pictures? here is where my tach sits.
Attached Thumbnails tweeters in a-pillar-dscf1489.jpg   tweeters in a-pillar-dscf1473.jpg
Old Jul 15, 2008 | 12:56 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You should ditch the dash and sail panel setup all together and do a nice door panel setup, trust me you'll be happier with this upgrade. What tweeters do you have now? You can pick up a nice set of 6.5's and do a really good setup in a pair of door build outs pretty easy and cheap.
Old Jul 16, 2008 | 08:41 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
you want them as far forward as possible, to minimize pathlength differences.. if your head unit has time alignment features, this can be accommodated for, otherwise just as far away from your head as you can and play with the aiming.. likely the best location for tweeters if you can keep the pathlength issue at bay.
Old Jul 18, 2008 | 10:50 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Originally Posted by 1991CamaroRslow
You should ditch the dash and sail panel setup all together and do a nice door panel setup, trust me you'll be happier with this upgrade. You can pick up a nice set of 6.5's and do a really good setup in a pair of door build outs pretty easy and cheap.
Old Jan 4, 2009 | 02:20 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
you can mount the tweeters on the windshield itsa very easy install that requires no drilling holes in the pillars all you need is a hot glue gun you can mount them in the top coners of the windshield just clean the glass real good before you glue them on there
Old Jan 6, 2009 | 05:31 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
you can also mount them to the back of your review mirror. i know that sounds weird...but the sound bounces off the glass back at you. takes some angling obviously. but, the door is probably the best spot....the 6.5 comp set never lets ya down
Old Jan 11, 2009 | 10:36 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
I hope the last two posts were jokes...
Old Jan 13, 2009 | 02:56 AM
mines not. its actually been done, obviously some custom work on the mirror, but it sounds ok. its not near as good as a custom door, or a-pillar
aharvel50
Sep 21, 2015 07:31 PM
tcflint
Sep 14, 2015 04:55 AM
Omega
Aug 10, 2015 12:46 PM
BowtieFever
Car Audio
Dec 20, 2001 10:13 PM
Mike Harvey
Car Audio
Dec 10, 2000 03:41 PM
