Brown Wire Isues
Old Jul 29, 2008 | 08:09 PM
dieseldust's Avatar
Car: 1989 Firebird
Brown Wire Isues
1989 firebird stock radio harness does anyone know what the brown wire and the black wire with a light blue stripe are for ??
James
Old Aug 5, 2008 | 12:39 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Brown Wire Isues
Brown should be the dim signal that will dim the faceplate.
I'm not sure about the black though. Could that be the noise wire that keeps ignition noise from coming through the radio?
Old Aug 5, 2008 | 03:15 PM
ParkerTPIz's Avatar
brown wie is def a dim signal. i accidentally hooked it up as the ground once. it worked until i turned the head lights on! haha then i pocked like 2 fuses.....lesson well learned
Old Aug 12, 2008 | 12:53 PM
dieseldust's Avatar
Car: 1989 Firebird
Thanks guys i guess i will have to hook up a direct ground to the frame or battery then cause i do not have a black wire in the factory harness, weird not to have one i think thou you would think they would have a black ground wire in the harnes.
Cheers
James
chazman
Aug 28, 2018 03:25 PM
maroe624
Apr 16, 2017 08:29 AM
db057
Sep 4, 2015 07:57 AM
Bryan F
Aug 27, 2015 07:28 AM
chazman
Aug 22, 2015 02:01 PM
