PRoblem with Pioneer headunit
Old Aug 7, 2008 | 02:54 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Hi guys. I'm having a problem with my Pioneer DEH P7200. Its an older unit, but has served me well through the years I've owned it. It currently driving Infinity Kappa 693's in the sail panels, and stock/original 4x6's up front. No amps, no subs. I have Pioneer's iPod adapter installed. Its wired properly with an adapter, no hacking into the factory wiring at all. All the connections are soldered and taped (I was out of heat shrink tubing).
Yesterday, it stopped producing any sound at all. It powers up fine and seems to be functioning as normal. CDs will play, it seems to get AM/FM signals, and it recognizes the iPod adapter and I can still control my iPod with it. Just no sound comes from the speakers. I do get a slight pop from the left rear speaker upon power up, but nothing else.
I'll be checking for shorts at the speakers when I get home tonight, and I have the stock CD player I can put back in for testing (even though the CD player no longer works). Anything else I should check? Think my headunit has finally gone kaputski after 10 years?
Dave
Old Aug 7, 2008 | 03:54 PM
MISTER13's Avatar
Car: 1989 Camaro RS
Engine: 350 T.B.I
Transmission: 700R4 w/shift kit 3500 stall
Axle/Gears: ??? Soon to be 3.73
Re: PRoblem with Pioneer headunit
[quote=Big Dave;3850093]Hi guys. I'm havinP7200. Its an older unit, but has served me well through the years I've owned it. It currently driving Infinity Kappa 693's in the sail panels, and stock/original 4x6's up front. No amps, no subs. I have Pioneer's iPod adapter installed. Its wired properly with an adapter, no hacking into the factory wiring at all. All the connections are soldered and taped (I was out of heat shrink tubing).
Old Aug 7, 2008 | 04:11 PM
MISTER13's Avatar
Car: 1989 Camaro RS
Engine: 350 T.B.I
I don't know if I'm in the right spot to reply to your question, but I have seen this promblem before! I don't know why alot of the older pioneer's lose their sound from direct hook-up, but it can be resolved very easily! All u have to do is run a small amp! Your sound will have to come from the rca jacks now! I can almost promise that this will work too!!! I have had this problem on more than one occassion with pioneer's!!!
Old Aug 8, 2008 | 07:13 AM
Big Dave's Avatar
I reinstalled the factory CD player and everything worked but the left rear speaker. So I took it out and found one of the wires was grounding to the body of the car. Fixed that, put my Pioneer back in, all is well.
Dave
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
