should i keep my orig. sound system?
Old Oct 21, 2008 | 11:12 AM
87HarfordCouny's Avatar
Car: 1987 firebird formula
Engine: lt1 350
Transmission: 2.73
I am currently trying to decide if i should keep the car system stock or replace it. I know that cars that have orig. stock parts are worth more. And i want a nice sound system at the same time. Should i replace the orig. audio system for a nice sound system or is a stock system add value to the car?
And if i did change it out i want a system that blends in to the original looks of the car. its a 1987 Pontiac Firebird and a black dash board.
Old Oct 21, 2008 | 11:30 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: should i keep my orig. sound system?
Thats up to you bro. I would replace it all, but keep the stock stuff if you are worried about it. You could always put it back in.
Old Oct 21, 2008 | 09:18 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You could also keep the original deck and hook the speaker leads to a line level converter and run an amp off from that. Then you'll have the stock look and an amplified system. I'm debating doing this to my 89 RS which has a stock looking deck in it. It's not the most desirable way to do it as converters can introduce noise into the system (especially cheap ones), but it allows you to maintain a stock looking appearance.
Old Oct 21, 2008 | 09:51 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I agree. If you want something better then upgrade and keep the everything to return it back when needed. I think a original looking car to me is worth more.
Old Oct 22, 2008 | 05:58 AM
hellsatan's Avatar
Car: 89 IROC
keep it if you are looking to resell it in the future. Or if you do sell it soon and end up putting a deck in ask the buyer if they want the orig parts or put it in your add "stock parts included"
92projectcamaro
Jan 18, 2016 08:00 AM
Blue419
Sep 10, 2015 01:03 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Slush92RS
Sep 2, 2015 08:56 PM
