possibly dumb question, but w/e
Old Oct 22, 2008 | 06:44 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
So i am looking at a sub setup to put in the trunk of my camaro and i have been shopping around on crutchfield and i was looking at an amp that is rated at 250 amps at 4 ohms and 450 amps at 2 ohms. i was thinking about a sub that is rated at 400 amps rms but it is a 4 ohm sub.
my question is this...
the amp can only power one sub, and i cant find a 2 ohm single voice coil sub.
can i run a single sub and run it in parallel with a 4 ohm resistor to get a total of 2 ohms and take advantage of the amp's ability to push 450 rms amps at 2 ohms?
sorry if this is a dumb question, but it seems like common sense to me that it would be possible
then again i am a complete noob so...
Old Oct 22, 2008 | 07:01 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: possibly dumb question, but w/e
nvm. Forgot that the wattage would be halved as well.
Old Oct 22, 2008 | 07:27 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
you mean watts cuz 250 amps would be like a 2/0 wire goin to the sub let alone 400 amps but if you want 2 ohms at the amp why not buy a dvc 4ohm sub and wire it in parallel? hope that helps cuz your question is kind of hard to understand
Old Oct 22, 2008 | 07:33 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Who says that the amp you want can only power one sub. I have a mono block amp that has six 8 inch dvc subs in my daily driver(not my iroc) all seried and paralleled to get 2 ohms(actually 1.5 ohms) and never had a problem with it. You dont want to do the resistor thing. Like brennan said, get a dvc sub with 4 ohms and parallel them or get 2 single 4 ohm subs and parallel them.
Old Oct 22, 2008 | 08:17 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
wow, yeah, I meant watts.
the reason I don't want two subs is because two subs are more expensive than one LOL. I figured that if I could get more watts at 2 ohms I would do it that way. I guess I will do one sub and get a better amp
What I was trying to say was I want one sub and I want to get the most bang from my possible amp. The amp can put out more watts at a lower resistance (just like any amp on the market) so I was going to pair it with a 2 ohm load. Problem is I can't find a 2 ohm sub. I know that I could simply get two subs, but I'm trying not to spend too much
Last edited by RED_DRAGON_85; Oct 22, 2008 at 08:30 PM. Reason: Automerged Doublepost
Old Oct 22, 2008 | 08:33 PM
jermdm's Avatar
Car: 1989 Iroc-z
Yeah you would get more watts a 2 ohms as long as the amp is 2 ohm stable. Dont blame you on not wanting to buy 2 speakers as it's more expensive. A 4 ohm dvc sub would be more up your alley and might be less money than buying a more powerful amp. Just have to shop around as there is good deals all over. The only 2 ohm single coil sub I've ever seen is a kicker solo barc and its quite expensive. Good luck hunting around.
Old Oct 22, 2008 | 08:39 PM
Brennan's Avatar
dvc=one sub with two voice coils which gives you 4 terminals so you can wire it in parallel which will give you 2 ohms at the amp assuming the voice coils are 4 ohms each and check ebay if your on a budget
Old Oct 22, 2008 | 09:26 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
if i understand correctly, a dual voice coil sub is kinda like two subs in one.
if i wire a DVC sub in parallel with itself to get a 2 ohm load and my amp puts out 450 watts rms, and the sub is rated at 400 rms, wont that overload the amp?
i mean, 400 x 2 is 800 isnt it?
maybe i dont understand how this works, but thanks for helpin me out
Old Oct 23, 2008 | 09:31 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Bueler. Bueler. Bueler. Anyone?
Old Oct 23, 2008 | 09:38 AM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Wiring up a dvc sub in parallel to bring it down to 2 ohm will not double your amps total output wattage. It will still only put 450 watts to your dvc sub, and if the sub is 400 rms, then you will be in perfect range for power. Always better to overpower a sub than underpower it.
Old Oct 23, 2008 | 10:00 AM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Old Oct 23, 2008 | 12:49 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
cool thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
Caspar
Jun 19, 2016 11:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
