Intalling aftermarket deck
Old Oct 23, 2008 | 11:55 AM
3.1Cruiser's Avatar
Hey guys, new here. I have a 1992 Camaro RS and im just about to put in my stereo system which just needs a deck wired up and my sub and amp. Now my question is, How in the world to get my deck to fit in where the stock one was? Do i need an adapter kit? If so, where do i get one from? And if not, what do i do?
Old Oct 23, 2008 | 02:03 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: Intalling aftermarket deck
Yes you need a installation kit, you can get them at a local car audio store like mickey shorr or car tunes. If not most auto places carry them too like murrays or auto zone. Can even get cheap ones from a department store like majier. After you get that its rather simple just unscrew the plastic trim pieces around the stock radio 2 screws hold it in then place your aftermarket deck in the installation kit and install it back in your car. While your at the store you should pick up the wiring harness for the car as well, it will make the wiring much easier to install. Good Luck!
Old Oct 23, 2008 | 04:55 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
welcome to the board. just go to walmart and get the GMkit. it comes with the 1-1/2Din adapter and the wiring harness and the wiring diagram. It was like $8...
Old Oct 23, 2008 | 06:58 PM
Gibbyzracing's Avatar
Car: 91 RS Vert 86 Cutlass
Engine: Sbc
Transmission: T5 400 Turbo
go through a couple junk yards... They got the kits for like 2 if you can find one in a camaro if not walmart works good 8-12
Old Oct 23, 2008 | 09:29 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
yea everyone pretty much hit the nail on the head here. keep in mind an after market deck will stick out a little bit over stock but not much of a big deal. good luck with it
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
