Replace cassette radio with CD unit
Old Oct 30, 2008 | 12:10 AM
gcbuie's Avatar
Car: 89 Firebird Trans-Am
Engine: 5.0 TPI
Transmission: THM 700 R4
Axle/Gears: 273 Limited Slip
I have an 89 T/A, with a delco lock cassette unit that is locked. I would like to buy a CD radio to replace it with. I also have the steering wheel controls.
Anyone?
Old Oct 30, 2008 | 12:25 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Re: Replace cassette radio with CD unit
OK so you'll need a wiring harness and maybe a antenna adapter plus you'll need to get a head unit. Best buy is the best place, has everything and if you don't want to do install it they well for a small-ish fee (but really it is easy to D.I.Y.). Steering wheel controls from what I see well not work by them selves with aftermarket. Tho I have seen things on the web that say they can make you stock steering wheel controls work with aftermarket radio. Here is a adapter that a ran across, mite work no promises. Good luck
Old Oct 30, 2008 | 12:47 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
The only thing that looks like sucks out of that kit is you'd have to drill a hole to mount the IR LED, and have it pointing at your headunit. Some aftermarket decks have steering wheel controls built it, but I don't think they're very common.
Eclipse models seem to support steering wheel controls more than other models. Call up Crutchfield and see if someone can point you in the right direction.
Old Oct 31, 2008 | 01:55 PM
gcbuie's Avatar
Engine: 5.0 TPI
Thanks guy's,
I will look into it, I was hoping to find another Delco unit with a CD player instead of the cassette unit in there now. So it looked stock...
Old Nov 1, 2008 | 01:32 AM
RenoReno2's Avatar
Sometimes these smaller shops keep old radios that work ok you may get lucky check them out.
Old Nov 1, 2008 | 09:06 AM
gcbuie's Avatar
Engine: 5.0 TPI
Thanks RenoReno, I will check into it...
Old Nov 1, 2008 | 09:15 AM
RenoReno2's Avatar
You could always look into bone yards
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
ZsTransAm
Aug 11, 2015 07:30 PM
