Where to mount so that it is hidden and 12 disc cd changer.
Old Jan 10, 2009 | 10:25 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Not sure where to mount a amplifier so it would not be seen. I read in the forums that it can be mounted to the back seat and hidden behind it. I'd like to keep it from getting hot as well. Don't really car for the rear seating mounting. I also have 12 disc cd changer that I would like to mount hidden as well. As anyone made a well box that just holds the amplifier and a 12 disc cd changer? Just seems like a hard task to figure out. I want to use the stock speaker locations as well. So I don't want to use one of those well subwoofer boxes. I'm thinking of a enclosure in the well, that would hold the amplifier and the 12 disc cd changer. Probably would want some type of hinged lid so I could access the 12 disc cd changer. This would be going in a 87 Trans AM. Probably put a couple of cooling fans in the enclosure to keep everything cool.
Old Jan 11, 2009 | 07:13 PM
asting's Avatar
Re: Where to mount so that it is hidden and 12 disc cd changer.
I think you pretty much figured it out. That well is your best bet. I was going to suggest that you add fans, but then you had to add that last sentence :P.
You can run wires through that side vent and through the trim or just under the trim at the bottom.
Also, just build a plate that covers it and then a bottom piece to mount to. It shouldn't be too complex.
Old Jan 11, 2009 | 09:22 PM
Steveh4263's Avatar
Engine: 5.7 LTR
I should have really edited that message. Quite a bit of doesn't make any sense. LOL! I wonder who makes a custom enclosure such as the one I would like to have made?
Old Jan 11, 2009 | 09:31 PM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
https://www.thirdgen.org/forums/atta...s-scan0006.jpg
https://www.thirdgen.org/forums/attachments/car-audio/169182d1230862312-post-pics-your-stereos-scan0007.jpg
https://www.thirdgen.org/forums/atta...s-scan0009.jpg
Old Jan 11, 2009 | 09:48 PM
Steveh4263's Avatar
Engine: 5.7 LTR
I wanted a enclosure low enough that I could still put something in the well on top of the enclosure. Working out the logistics of how to get everything to fit the way I want it to is perplexing. I don't have access to the car until spring anyway. So I'm putting the cart ahead of horse.
Old Jan 12, 2009 | 04:03 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
if you dont want to carry the factory spare wheel, you can mount the amp and changer in that spot. it will be well hidden and no danger over heating.
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
drb930
Sep 9, 2015 10:53 PM
scottmoyer
Sep 7, 2015 07:06 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
