Dash: 6/5" speakers
Old Jan 24, 2009 | 02:02 AM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Dash: 6/5" speakers
Okay so i took my dash pad off tonight so i can start the work and cover it in vinyl. In the process i test the fit of the Rockford 6.5" Power Speakers. The basket was only slighty too large. I'm going to remove the 4x6 brackets and fab up a bracket for the 6.5". There's plenty of room to do it, just need a bracket that will allow it. I think i'll just use 2 separate pieces and run them on each side with mounting holes for the 6.5 to use 2 mounting locations.. If possible i'll run a smalled piece parallel to each other from the other pieces to use all four mounting spots on the speaker. Will let you know how it goes as I progress.. my welder is currently down so i'll have to go to a friends..
oh.. another thought.. i may just go to the JY tomorrow and grab an extra set of brackets and file them down and see how that works.. just another idea
Last edited by MikeSmith0890; Jan 24, 2009 at 02:03 AM. Reason: Automerged Doublepost
Old Jan 24, 2009 | 11:25 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: Dash: 6/5" speakers
As long as you're in there you might think about putting some foam baffles in there and stuffing them with some polyfill.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
