Speakers
Old Feb 11, 2009 | 04:08 PM
GT150's Avatar
Car: 1988 IROC-Z
Transmission: 5 speed
Axle/Gears: 3.08 posi
Speakers
I'm not a stereo guy, I know one thing about speakers, music comes out of them,...........sometimes. One of my back speakers was not working, I took it out and cleaned all the connections on the speaker and the wires coming off the radio. I then used a jumper wire from the radio to a different speaker, and that one worked. I then hooked the old speaker back up and used the jumper wire from where the gold wires go into the speaker paper to a different speaker and it worked.
My question is the non-working speaker looked great, no torn paper contacts looked good and worked, but no sound. Where do they fail?
Mike
Old Feb 11, 2009 | 09:05 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Speakers
Sometimes a broken connection will occur where the
flex wire connects to the voice coil wire-this connection
is on the front side of the cone and is usually covered
with glue or varnish,sometimes this problem is able
to be repaired.Burnt-out voice coils can occur if amp
shorts out or speaker power rating way exceded.
Old Feb 11, 2009 | 10:51 PM
superT's Avatar
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
Re: Speakers
both are true. but a tensile lead (wire from terminal to coil) may be coming apart inside. that said i have been installing stereos for 12 yrs and if you have a component speaker going bad save yourself some money and buy new. because repairing it is not worth it and you probably won't find anyone who will repair it. although if they are already aftermarket the manufacturer may replace them if under warranty
a couple of good brands that will last are jvc, pioneer, fusion, and lanzar
Last edited by superT; Feb 11, 2009 at 11:14 PM. Reason: not 15 yrs but have been doing it since i was 15 yrs old
Old Feb 12, 2009 | 08:28 AM
GT150's Avatar
Car: 1988 IROC-Z
Re: Speakers
Thanks for both replys, I will be getting a new speaker.
mike
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
wanext
Oct 6, 2015 12:18 AM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
codeysabatini
Sep 20, 2015 11:36 AM
