Small Radio POD
Old Feb 17, 2009 | 01:06 AM
DanTeix's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Small Radio POD
Has any one noticed how terribly small our radio pods are. I Just bought a new A/M headunit that has alot wires on the harness and it just does not pit in the POD. I was wondering if any one has experienced a similar problem and had a solution.
Thanks,
Dan
Old Feb 17, 2009 | 02:42 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Small Radio POD
you just have to make room and shorten the wires as much as possible...
Old Feb 17, 2009 | 10:53 AM
DanTeix's Avatar
Engine: 305 TBI
Re: Small Radio POD
Yeah i figured that much I am going to have to take a more indepth look at it when I get home but the head unit is cool.
Dan
Old Feb 17, 2009 | 02:18 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: Small Radio POD
it can be done. I have all the wires for my head unit back there, including two thick wire harnesses, RCA cables, antenna cable, etc...
Old Feb 18, 2009 | 05:28 AM
vahn401's Avatar
Re: Small Radio POD
I don't know for certain, but with Camaros it may vary by year. I have personally owned 2 86' models, and have never had a problem shoving everything back there. On the other hand, i've worked on 2 91-92 models, and I believe I had a hell of a time putting a radio in. Its been a while, but I recall having to make a small cut in the carpet behind the radio for some reason, just to get the radio in. (can't remember if i had to move something or what)
Old Feb 21, 2009 | 01:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Small Radio POD
Camaros have more room in there than Birds do, because their consoles are one piece and we have the lower portion of the pod and the front of the console to deal with. In order to ATTEMPT to flush mount my headunit in my radio pod, I had to notch out the rear support where that one little nut is that holds the pod in place on the floor. I have to re-cut it, because now I don't have ANY room under there, with the big cable running to my iPod interface unit, and my h/u is no longer flush mounted.
Veaceonee
Sep 29, 2016 08:15 PM
Jorlain
Oct 8, 2015 01:57 AM
gta892000
Sep 16, 2015 12:37 AM
iroczz89
Sep 12, 2015 04:55 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
