I got 6 1/2s into dash!!
Old Mar 15, 2009 | 12:47 PM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
Ok this was wayyy easy. I had some 6 1/2 Infinity speakers that where in my 94 camaro and I didn't want them to go to waste since they were almost new. They wouldn't fit in my door because I have power windows so I decided to check out the dash. I thought I had read some people tring this but idk I'm prb no the first but I'll tell you what I did. I just removed the entire old speaker and brackets from the dash. Then I just sat my 6 1/2s right in the same spot without the brackets. The tweeter on the speaker actually sticks up farther then the speaker so once the pad is put back on it holds the speakers in place and they don't move at all. You have to be careful when putting the pad back on but it was really easy and sounds a lot better.
Old Mar 15, 2009 | 01:34 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: I got 6 1/2s into dash!!
So you actually have your dash pad holding the speaker in place?
Your dash pad will crack (if it's not already). Sounds like your asking for a whole new world of rattles, ie, improperly mounted dash pad and/or speakers...
Old Mar 15, 2009 | 02:46 PM
BlKnt18's Avatar
Actually it fits perfect. No rattles. The dash already has a crack but even if it didn't I'd still do it. I mean this is a perfect fit. Everything went back together great. Plus my exhaust is so loud you wouldn't be able to hear a rattle if there was one....got new exhaust coming next week. You don't have to do if you don't but it works great and is not a hack job. Also there is no pressure on the pad because they fit so well, but still don't slide around.
Old Mar 15, 2009 | 02:56 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
PICS!!!!
Old Mar 15, 2009 | 03:13 PM
BlKnt18's Avatar
Well I already put the pad back on but I could give pic through the speaker vent maybe??
Old Mar 15, 2009 | 03:17 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Cant go wrong with Infinity ! I have perfects 3 way up front and 3x way 6x9 in the back. Even turned way up those infinities are crystal clear and you can hear absolutely every sound.
I use to roll with the Kappa series but I have not been able to locate them anymore, musta stopped making it
Old Mar 15, 2009 | 11:19 PM
BlKnt18's Avatar
I tried to get pics but you can't see anything really since the dash is back on. If you really want to do it just get some 3 way infinity 6.5 round speakers and set them right where the old ones were and that's it.
Old Mar 16, 2009 | 02:01 PM
BlKnt18's Avatar
I also want to say that since my dash was cracked slightly this may or may not have helped the install. I know the driver's side is pretty tight so if you crack your dash that is all on you. I'm just saying it worked for me. Yours may be different.
Old Mar 16, 2009 | 02:16 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
without doing ne thing to separate the front and back of the speaker ur messing up its frequency responce the speaker may also hurt itself if u turn it up to loud because its free air state may make it extend to far
Old Mar 16, 2009 | 02:22 PM
Stephen's Avatar
Car: 87 GTA
If the dash pad is pressing on the tweeter, wouldn't that make the tweeter useless & not work anymore?
Old Mar 16, 2009 | 03:52 PM
cdoyle's Avatar
So the speakers are just sitting up in the voids of the dash? Not mounted to anything? Nothing separating the front and back waves of the speaker?
What's stopping the speaker from moving around when you hit a big bump in the road?
Old Mar 16, 2009 | 08:42 PM
BlKnt18's Avatar
The tweeter is a hard plastic on these so touching them does not affect anything. The dash pad hold them down right right so they don't move. I just drove 3 hours of highway, then bumpy roads, and gravel and they are just fine. No one has to try if they don't want I'm just saying I did it and I like it. But like I said earlier my dash was already cracked on the driver's side on and around the speaker vent which may have affected the proper fitting.
Old Mar 17, 2009 | 07:02 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
I have done this same thing, fit two 6x9's in the dash only bolted to the dash pad itself (it obviously has a steel layer under the leather stuff) Widened the area the original speakers were in, took out the mounting brackets the original speakers were mounted to. No rattles no issues, fits perfectly. Only problem is the speakers' cone gets heated up real well by the sun magnified through the windshield and dried it out and cracked, had to replace them with a speaker that had higher quality cones.
Fit a tweeter in a pillar gauge holder (2 1/16) on both pillars for imaging.
Old Mar 18, 2009 | 06:58 PM
blackroc68's Avatar
INFINITY speakers suck thats my opinion> i had infinity Speakers in my house.I must have returned them 5 times under warranty,
Old Mar 18, 2009 | 10:27 PM
BlKnt18's Avatar
Ya idk I turn up these 6 1/2s and they can't handle just the radio's power and they should handle an amp. I think they may suck too.
Old Mar 19, 2009 | 09:05 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
if you decide to take them out, snap some pics for us!
Old Mar 26, 2009 | 12:29 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
That's because after a certain volume level the Head unit outputs a clipped signal in return you hear the distortion in your speakers, this distortion is actually damaging your speakers. With an amp, the speakers will be louder because they will be recieiving clean power via the amp and not the 12-16 watts that the head unit puts out (rms power not max, max power should always be ignored).
Even on an amp you can still recieive a clipped signal via a poorly recorded track on the cd and numerous other ways so you just have to be careful. But putting an amp on the speakers will help get rid of the distortion that you hear.
Old Mar 26, 2009 | 01:55 PM
BlKnt18's Avatar
I wondered if that may be the case but I didn't know for sure. I keep them down anyways because I hate the distortion sound.
Old Mar 27, 2009 | 12:37 AM
cdoyle's Avatar
also you have them just sitting in the dash is part of the problem too, it's been mentioned that you need to separate the rear/front wave. they are basically canceling each other out.
Old Mar 27, 2009 | 02:53 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
i run infinity speakers in my car with a 700watt 4 channel amp on them and 2 12" rockfords in the back with a 700watt monobox amp and i can crank them and they are crystal clear.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
