Opinions on this amp.....
Old Mar 16, 2009 | 06:43 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
Hey guys, what do you think of this amp?
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
I bought a Camaro a few months ago and it has a Targa amp in the back that I think is blown. It has 4 speakers hooked to it and I only have two from opposite sides of the car working. I'm not looking to have a killer system, just want something that sounds decent at a fair price and replaces what I have now without having to rewire the car. Is it possible that the head unit could be causing the problem? I know very little about car stereo. Thanks in advance for any help.
Old Mar 16, 2009 | 07:01 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Opinions on this amp.....
i wouldnt know how to tell you to test the head unit unless you take and bench test it, the amp seems good, i got a cheap amp for my 10's (rockford p2's) and it kicks some major butt.....i keep it turned down, the best way to describe the way i like it is like how a caddy with a factory sub sounds, its enough to feel it and shake few things (i still had to put sound mat down) but it aint crazy, now if i crank it, it gets pretty hard, what im getting at is you will prob be ok with that cheap amp since you said
"sounds decent at a fair price"
now you could have bad speakers to you may want to swap the speaker wires and see if the others work that way
someone thaty knows alot should chime in to help more
Old Mar 16, 2009 | 09:53 PM
Engine: L98 5.7
Thanks for the response, I appreciate it. I actually did test the speakers by putting in another pair and I came up with the same problem. I wish I knew how to test some of this stuff as the deck is a Blauplunkt unit. Its a few years old, but still a nice piece.
Old Mar 19, 2009 | 10:30 PM
skitztikwon's Avatar
if your signal input is comeing from rca jacks swap them if the same side still works its your amp if nothing works if could be both
Old Mar 20, 2009 | 06:02 PM
Engine: L98 5.7
Thanks for the idea, I appreciate it!
Old Apr 3, 2009 | 01:45 AM
Engine: L98 5.7
I actually got this setup to work......I had one bad speaker and replaced it with another bad speaker......
I swapped channels, changed out the speaker wires and narrowed it down. I also had the amp all misadjusted since I know nothing about amps.
After replacing the speaker and tweaking the adjustments, it sounds pretty good. Not bad for no cash outlay!
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
