POWER QUESTION
Old Mar 23, 2009 | 07:04 PM
88_TeenTrans's Avatar
Car: 1988 Fire Bird (T-Roof)
Engine: 5.0L 305 TPI
POWER QUESTION
I have a battery with a 90Amp Res. stock alt. and I have ONE Pioneer Premiere sereis sub its 1200Watt Peak 400Rms is is the TS-W1207D2 i have a Kenwood 929 amp with a peak of 100 watts and 350 RMS i have bin told they are a close enoguh match up, but I am asking opinions if i could run this without damaging car ec.
Old Mar 23, 2009 | 08:42 PM
vahn401's Avatar
Re: POWER QUESTION
i'd check the specs on your amp, i've never seen any car audio product where the rms rating is higher than the peak power. Also, is the subwoofer rated for 4 ohms? And do you know if it is a single or dual voice coil subwoofer?
Old Mar 24, 2009 | 01:13 PM
Re: POWER QUESTION
Sorry I meant 1000watt max for my kenwood and my sub is a DUAL 2 Ohm voice coil
Old Mar 25, 2009 | 11:57 PM
Civerus's Avatar
Re: POWER QUESTION
Dual 2 ohm isnt too common, usually they run dual 4 ohm I believe, and when you series a single sub it goes to 8, and parallel to 2, unless its meant to be run off of a mono block in which then 2 would make 1 and mono's can run 1ohm stable. If the Kenwood is 1000w, then its at 1ohm bridged usually.
So for 2 ohm, take the bridge, and half the wattage. So now you have 500w @ 2ohm, same with 4 ohm, half it, so 250w at 4ohm, 125 at 8, etc, and thats bridged. If its a 2ch, then its 250w x2 @ 2ohm.
Now if its a dual 2 ohm sub, then wired in series it would draw at 4 ohms which would be 250w per channel, if wired in parallel it would be 1 ohm and draw 1000w (500w per coil) which would be spot on, and then you just lower your gain a tad. No matter what, parallel or series, wire it in the bridge if its a single sub. The test reviews on that particular amp say it CAN in theory put out 1000w, but most likely will not. Just remember, use a cap, it'll prolong the life of the amp and the sub by stabilizing the voltages it draws.
Overall, that amp, wired properly, is perfect for that sub. Make sure you're running at least 4g power/4 or 2-0g ground. And at least 12g for the sub itself.
Old Mar 26, 2009 | 08:45 AM
Re: POWER QUESTION
will my stock altenator be ok?
Old Mar 26, 2009 | 08:57 AM
Civerus's Avatar
Re: POWER QUESTION
Should be as long as you have a capacitor, hook it all up, through a cap, and turn your lights on, and turn the music up, if your headlights still dim then you still need more.
Old Mar 26, 2009 | 02:25 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: POWER QUESTION
caps are no good. not worth the money. do it right and do the big 3 upgrade
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
