Odd Problem
Old Apr 1, 2009 | 09:56 PM
Twitch RS's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: 700 R4
Odd Problem
I picked up a set of pioneer 6x9s for the rear sail panels and when I installed the speaker it sounded good however
Well when I turned it up the new speaker started to fizz
So I figured I didn't get a good connection so I puled it off and when I touched the wires to the speaker it didn't work.
I pulled the other new speaker out and tried it...nothing
then as I was holding it and messin with radio it started to work a little when was fine for like ten seconds then died...
and ideas? I am guessing bad wiring really don't wanna run a new line ugh
don't get what could have happened cause nothing changed
Old Apr 1, 2009 | 11:18 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Odd Problem
Sure you didnt get the positive and negative switched around?
Old Apr 2, 2009 | 10:02 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Odd Problem
While it might sound a bit funny, wiring backwards would not stop the speaker from playing, it would just be out of phase with the other speakers. It sounds like its either bad wiring, bad connection, or a bad channel on the radio's amp. You could start at the radio end and try and tap into the wiring (kinda messy), as this would tell you if you have a break in the wiring between the radio and the speaker location.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
