Did I put a bunch of holes in my gas tank?
Old Apr 20, 2009 | 12:40 AM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
I mounted my amps, & a few other things right over the tank. I used one inch screws. I know its a bone head thing to do, but its done. I was thinking that one inch would be fine, & I did stay away from the center Where the hoses are. Am I ok?
Old Apr 20, 2009 | 01:07 AM
Stephen's Avatar
Car: 87 GTA
Re: Did I put a bunch of holes in my gas tank?
1" screws?
How thick was the mounting feet? On a board? Or JUST the thin metal mounting feet?
Old Apr 20, 2009 | 01:41 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
lol 1 inch screws? on like 1/8 thick sheet metal?
Old Apr 20, 2009 | 01:54 AM
Stephen's Avatar
Car: 87 GTA
WHERE did your screws go in? Got a pic?
My car has the Access Door, so I went & measured for you, with my old scale for when I was a CNC machinist, so it is SPOT ON.
I measured from 3/4" to 1" clearance, floor to tank. So depending in WHERE you put your screws & the thickness of the mounting feet on your amp.....
At the very least you touched the tank, but didn't penetrate it. Which is what I suspect happened if you never felt it go through the tank.
Chances are your safe & didn't puncture the tank, but no guarantee on that!
Old Apr 20, 2009 | 01:56 AM
STRIKER911's Avatar
Car: 89 RS
Originally Posted by Stephen
1" screws?
I used it to mount the amps so about 3/8ths total.
LOL thanks for the encouragement. I got some for ya. Get a v8. Hole in the tank or not u still see me doing this right by ya.
Old Apr 20, 2009 | 01:58 AM
STRIKER911's Avatar
Car: 89 RS
ill take a pic and bring a tape with me.
Old Apr 20, 2009 | 02:04 AM
Stephen's Avatar
Car: 87 GTA
What he said may not have been of any help, but it is down wrong to have bashed him on owning a V6 car.
Don't treat other members that way. Should we bash on your 305 TBI?.....
Old Apr 20, 2009 | 02:23 AM
STRIKER911's Avatar
Car: 89 RS
Ya I agree man just more of a joke then anything. I had a v6 rs myself. Was it a lil low? Ya. But I got kicked when I was down, so to speak.
k so back to the post. the screws are 7/8ths, & forgot to give for the carpet. 5/8ths went threw. Hope this isn't to confusing. I will post the pics, and let me know if I should measure. Forgot that the fuse block in the rear center has a screw in it too
Attached Thumbnails Did I put a bunch of holes in my gas tank?-zz-018.jpg   Did I put a bunch of holes in my gas tank?-zz-019.jpg
Old Apr 20, 2009 | 02:51 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Honestly, I would get a some much (MUCH) shorter screws to replace those 1 inchers. They may not have punctured the tank but one good bump or pothole might...
Old Apr 20, 2009 | 03:01 AM
Camaroz2892's Avatar
Car: 92 Camaro Z28
Old Apr 20, 2009 | 07:05 AM
STRIKER911's Avatar
Car: 89 RS
Ok I will do that. I was thinking that if I did make a hole that it was best to leave it alone since the hole, or holes should be plugged. It would be hard to tell if their was any holes,without dropping the tank right?
Old Apr 20, 2009 | 07:23 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Might be able to turn on the car and when the car primes up the fuel pressure will let air escape back there and you might be able to hear it. Either way, something needs to get done, this was the same problem the Crown Vic's had, get rear ended and a bolt (or screw as it may be) punctured the tank and caused a spark. Something you don't want to play with either way. Take all the screws out to replace them with shorter ones either way, and when you have all the screws out, have someone turn the car into the on position, but do not start, so that the pump will prime and build up pressure. If you hear whistling or the sound of air escaping, then you likely punctured the tank. This is of course a half as test compared to dropping the tank and being sure. Definitely get shorter screws in there immediately!
Old Apr 20, 2009 | 07:30 AM
STRIKER911's Avatar
Car: 89 RS
Ok. Thanks for the help. God how dumb do I feel right now. Might have thought about it if I ever had to, have dropped the tank in the past.
Old Apr 20, 2009 | 08:06 AM
50bmgshooter's Avatar
you can remove the screws and use a straight piece solid wire and see if it only goes down about 1 inch, if it goes in more then that you have a hole in the tank
Old Apr 20, 2009 | 08:43 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
What kind of screws are we talking about here guys....???
just regular sheet metal screws that you had to drill a pilot hole for? Or did you use self-drilling screws that made their own hole?
Im willing to bet that the sheet metal in the cargo area would deform upwards, or strip out, before the tank would get punctured. Its not paper thin... You'd have to really bear down on the screw after it went through the sheet metal. If you did that...then I dont know what to tell ya.
Ide still replace them with some sorta screws, but I HIGHLY doubt you have holes in the tank. If you are worried, do the wire sticking into the hole trick.
J.
Old Apr 20, 2009 | 10:47 AM
STRIKER911's Avatar
Car: 89 RS
J.
I bet im ok. I used sheet metal screws. Had to push pretty hard just to get threw the floor. I changed them to 1/4" screws.
Old Apr 30, 2009 | 11:52 AM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
When I put my amps in I just bought some Velcro pads and stuck em to the amp and it grabs the carpet really nicely, you can even set it against the well at an angle and they wont budge. Good alternative.
Old Apr 30, 2009 | 12:39 PM
STRIKER911's Avatar
Car: 89 RS
That would have been a good idea, but I used screws for security. I have had 4 break in's in the last 3 years, in other cars. One car had the amps screwed to the false floor & they ripped the whole floor out, with the carpet, & took it all.
On this car I put an alarm in, & screwed to the floor, so I will have time to load the shot gun.
Old Apr 30, 2009 | 01:43 PM
Morder.'s Avatar
Engine: LB9 305 TPI
Well, just my opinion, but screws arent exactly difficult to take out. If they want your stereo and break in your car, they are getting your stereo.
The alarm though, that should help.
Old Apr 30, 2009 | 01:51 PM
87350IROC's Avatar
Car: 87' IROC
Why not hide the amps? Under a seat, in the spare tire area, in the lock box area.
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
You've stated your car has been broken into a few times before so I recommend finding a better spot for the amps instead of the gas tank hump. They're just too visible. Not to mention the tank is too close to think about putting any kind of screw through the sheet metal over it.
Its a bit more work, but why not see how some of the other members around here mounted them inside their back seats? I was able to put two amps in there and still have a completely working seat. Not to mention reducing the eye candy for thieves to look for.
Old Apr 30, 2009 | 02:38 PM
STRIKER911's Avatar
Car: 89 RS
I could hide them, & in a way I did. 5% tint. Can still see in if you cup your hands by the glass to see in, unless the sun hits the window just right. I run my stuff pretty hard, with lots of power, so cooling is an issue when hiding amps.
Old Apr 30, 2009 | 02:59 PM
87350IROC's Avatar
Car: 87' IROC
Check out this thread. Plenty of room for cooling.
https://www.thirdgen.org/forums/car-...-area-amp.html
Old May 5, 2009 | 07:50 PM
pyrostick's Avatar
Car: 1992 Camaro RS 25th anneversary
Engine: 305 TBI
You could get louvers, if you like them, thats what i have and you cant see in that way just my
Old May 5, 2009 | 08:50 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you are probably ok you have about 3-4 inches betweeen the rear compartment and the tank, at least at the top.
here is a clue - do you smell gas?
Old May 5, 2009 | 09:10 PM
Stephen's Avatar
Car: 87 GTA
There is nowhere near 3"-4"...... https://www.thirdgen.org/forums/post...658-post4.html
Old May 6, 2009 | 09:59 AM
Car: 1990
Axle/Gears: stock
i had to bolt in a brace for the rear deck lid cover - and i also had to pull the carpet out to install the new carpet. if you do that you will see a very big gap between the top part of the original spare tire area - on the right side and it goes pretty far. its pretty deep and that is before you get through and into open area between the gas tank and the rear body body.
i dont know how far down he went but if he was near the top he had a good amount of space. cant say about further down but i base this on my actually seeing the space - i had to find out before dirlling. still i did not use screws longer than 1 inch, i did not have to.
i dont have to look at a picture, i look at the real thing.
"thomas you believe because you saw, blessed are they that did not see but still believe."
lol
Old May 6, 2009 | 11:10 AM
Stephen's Avatar
Car: 87 GTA
Maybe you are talking about the vertical wall of the flat tire well? Because there sure isn't 3"-4" on TOP (like you said before "about 3-4 inches betweeen the rear compartment and the tank, at least at the top."
You may not want a pic, but your gonna get one anyways now. I don't want anybody to read your post & think there is that much room. Pics are worth 1000 words.
Attached Thumbnails Did I put a bunch of holes in my gas tank?-tank-clearance.jpg
Old May 6, 2009 | 12:29 PM
STRIKER911's Avatar
Car: 89 RS
Your picture puts me at ease. With the longer screws, it would not have put any holes, but it would have been pretty close.
Old May 6, 2009 | 03:29 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
dude i wasnt hating or anything. point is just stop for a second. look at how thick the metal is. why do you think they call them "sheet" metal screws. chill man. wtf does motor size have to do with it? ignorant sonofa...
Old May 6, 2009 | 04:27 PM
STRIKER911's Avatar
Car: 89 RS
Lol. dude. That was a long time ago. Problem solved. But thanks for stirring the pot, again. Not falling for it this time.
Old May 6, 2009 | 05:18 PM
V6F1R3BRD's Avatar
Engine: 2.8 - LS1
it was a long time ago indeed.. not "stiring the pot". im just not gonna lay down while you insult v6 owners.
Old May 6, 2009 | 07:19 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
what business does a tbi guy have insulting anyone anyway? lol sorry i had to, anyway why not use rivets? thieves need a drill to get them out and there wont be anything pointy to puncture the tank plus they only stick out 1/4"-ish
Old May 6, 2009 | 08:22 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by Brennan
.....they only stick out 1/4"-ish
Actually, rivets (when put in) have like 1" shafts, then are snipped at insertion. So you need the full space behind there, to put the rivets in THEN they end up way shorter.
Old May 6, 2009 | 08:25 PM
Brennan's Avatar
i dont think ive ever used a pop rivet an inch long, not counting the part that goes in the rivet gun
Old May 6, 2009 | 08:40 PM
Stephen's Avatar
Car: 87 GTA
That's the part I was thinking about, but I got them backwards in my mind. Been years since I've had to use one.
The long part stays out & is not what is inserted to get seated. Me
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
