How does installing subs actually work?
Old Jun 6, 2009 | 04:39 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
I'm takling about in the back, in the trunk. Do you have to rip out take out all the seats and remove the carpet and run the cables on the floor? And then can you do it without ruining the carpet?
Old Jun 6, 2009 | 06:26 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: How does installing subs actually work?
in order to do it right yes. power on one side, audio on the other
definitely, unless your lazy.
Old Jul 9, 2009 | 07:12 AM
nemoose5's Avatar
Car: 1991 RS
The first time I installed a system of my thirdgen I didnt, and it looked a slight bit tacky.I didnt make a hole in my firewall so you could see the power wire running on the door jam.
Old Jul 11, 2009 | 03:50 AM
FirstLove1991RS's Avatar
Car: Building a 1984 Z28
Engine: 383
Axle/Gears: Posi Discs
Yea when i first got into audio i didnt know much but all i did was run it though the door jam too dosent look too bad.
but after a few years and learning a thing or 2 if you want to do it "Right" you need to put a hole in your firewall (if you are going with walmart subs go with your 8 gauge wire better then walmart like rockford go 4 guage then if you have the money to blow u can go with comp style like vibe or something go with 0 gauge)
then all you have to do is take off doorsails and the wheel cover next to the seats and left up the carpet run your set # guage wire and your 16 guage or so for remote amp turn on and your rca's. then you should be fine really simple I do it on the side for extra $ lol hope thats what your ? was. ohh ps carpet lifts up wont get ruined
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
