amp overheating :/
Old Jul 30, 2009 | 03:09 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
amp overheating :/
okay
so a couple of times when ive really pounded my system..the bass amp for my sub cuts off and the little light on it goes red *usually green..guessing its overheating?? southern cali weather probly doesent exactly help it lately either..so
the question is.
is there any way i can still bump my system without overheating the amp?
thanks
Mikey
Pic
vvvv
Old Jul 30, 2009 | 11:39 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: amp overheating :/
help..
Old Jul 30, 2009 | 11:59 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
How do you have your gains set? If they are set too high, you may be causing the amp to go into protect mode. If it is too hot to physically touch, you may have a possible wiring issue or just pushing it too hard. What ohm rating is your sub and how is it wired to the amp? (bridged?)
Old Jul 30, 2009 | 12:32 PM
87caprice's Avatar
Car: 1987 Chevrolet Caprice Brougham
Engine: 425hp 350 bored .060
Axle/Gears: 8.5 3.42 locker
You need to check your ohm load. Most of the time when amps are getting hot like that it always come back to be a wiring problem. Do you have a good metal ground and all connections are good. Hope you get it fixed properly.
Old Jul 30, 2009 | 02:37 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
okay..thanks alot to both of u =] my ground was coming off AND my gain was way to high. thanks guys^^
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
