Anyone get a deep 6x9 such as JL to fit?
Old Aug 2, 2009 | 10:20 AM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
I'd like to get a nice pair of 6x9's that have good bass to fit under the sail panel covers. I have a 10" sub to handle below 85hz, but need something to fill in the bass above 85hz. Has anyone had success in fitting a pair of 6x9's with a deep mounting depth? What modifications were involved? My car is an 89 GTA.
Old Aug 2, 2009 | 11:58 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Anyone get a deep 6x9 such as JL to fit?
I have fairly deep 6x9s in my car , the magnet alone is twice as big as factory. There is plenty of space , I took the fiberglass insulation and stuffed it away from the speaker.
Old Aug 2, 2009 | 12:28 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You may have something that I call speaker socks installed behind your sail panel. You could either remove them or make them bigger somehow. I think they are there to reduce reflection from the area inside. Not all Thirdgens have them though which is why some may not have noticed them. If you have high end speakers it would be a pretty safe bet that you would want some kind of sound absorption inside there.
Edit:
I also came across an install that included plywood (1/2"?) between the speaker and the mounting surface. I'm not sure if it was to absorb vibration or because of the speakers that were mounted inside at one time. -May be a possibility to consider.
Old Aug 2, 2009 | 12:35 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Thats part of what I had removed , I stuffed it down and kinda ripped it. One side I took it out completely not much difference. I was more worried about it catching on fire with the new speakers.
Old Aug 2, 2009 | 12:44 PM
Scorpner's Avatar
Engine: V6, V8
I would remove what's left if you can because if it gets wet it may lead to it rusting. If the speakers are actually contacting the metal behind it, then look at the distance it's sticking out and determine if you can put a spacer in without it touching the back. Then try fitting the sail panel. It's been a while but there should be enough space inside there without one.
Old Aug 2, 2009 | 02:10 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
So the 3" mounting depth that is often referred to is because of that fiberglass baffle? If I modify that or remove it I should be able to get a 4" depth to work?
Old Aug 2, 2009 | 02:40 PM
Scorpner's Avatar
Engine: V6, V8
You would have to measure to see what you have. I've gone past the limit on the fronts by cutting and moving a few things around. Just need to be careful and decide if it's worth doing or not.
Edit: I don't know if you've seen this or not. Link
Old Aug 8, 2009 | 03:35 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
bro take all that **** out and dynamat the walls and floor of the car. you can mount any speakers there i have alpine 6x9s on the walls. i'll take pics of them if you want. i also have what i did with the mat on my photobucket link in my sig
http://photobucket.com/Bosss
Old Aug 8, 2009 | 04:25 PM
Slick71ss's Avatar
Car: 87 Iroc
Axle/Gears: 3:27
Yeah, I ended up just getting Alpine 6x9's as well since they are a shallow speaker. They sound ok, but I know I'll end up regretting not getting a better speaker. The Alpines don't reproduce the lows like some other speakers can.
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
