Were did you hide your amp?
Old Feb 2, 2010 | 01:49 PM
  #51
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Re: Were did you hide your amp?
im running 1200 far as i know, i got the amp off a buddy of mine, but its sounds great and the power is always there when needed so, its all good
Old Feb 16, 2010 | 03:41 PM
  #52
confucius101's Avatar
Dont have the system in yet still working on other part of the car but i did hallow out the rear seat a few years ago plenty of room (4" depth) and air
and totally hidden
Old Feb 17, 2010 | 09:52 AM
  #53
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Heres a shot of my setup.
Its a bass tube with a DVC Audiobahn 10" sub. The tube fits perfectly inside the well width wise. To make sure it didn't slide left and right under cornering, I cut a piece of MDF with a notch to fit the inside the port of the tube and long enough to reach the protruding side of the trunk well- basically making a bridge, a brace, and a flat place for the amplifier. I covered it with cloth left over from re-doing my sail panels and mounted the amplifier on it. The only downside is that there isn't anything in that foot or so of vertical space under the MDF board/amp mount. I call it 'secret storage,' if you will.
On the plus side (and a huge one, I think), I don't HAVE to pull the shade down to hide the whole system. Unless you're really, REALLY looking for my amp/woofer, the metal deck of the trunk hides it quite well.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
