A single 12 installed
Old Dec 29, 2009 | 10:48 AM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Here's my set up of one 12. It consist of a kicker c12 and a crossfire cfa 202. The box was built out of 3/4 inch mdf and has about 1.7 cubic feet of air space. The box barely fit into the well but it went in with a little bit if force. Then I added a piece of mdf on top of it to give it that clean look. It sounds pretty good. Let me know what you think. Sorry the pics are a little dark.
Attached Thumbnails A single 12 installed-dcfc0618.jpg   A single 12 installed-dcfc0621.jpg   A single 12 installed-dcfc0623.jpg
Old Dec 30, 2009 | 06:00 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: A single 12 installed
Why did you angle the sub towards the back of the car?
Old Dec 30, 2009 | 07:36 AM
Car: 1991 Camaro RS
My opinion is that it sounds better facing the rear than facing up or forward. If I could have figured out a way to get it in the well facing the tail lights I would have done that. Not much room to work with.
Old Jan 1, 2010 | 03:07 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I have angled my subs back for years. I did an experiment with one 12 in a walmart box to prove the theory that it sounds better. The controls were the same song both times, same EQ settings, same speaker and box, and same amp. The first time I had the speaker and box facing forward sitting on the rear deck with the hatch closed. I played the song and it sounded decent. The second time I squeezed the box into the well facing backwards completely and it sounded alot better. It has something to do with the bass waves getting louder the further they travel(hence why we here people from a mile down the road when they are bumping). When the subs are angled back, it increases the distance the bass wave has to travel to get to the driver which makes the bass a little bit louder.
Wicked box man! You wouldnt happen to have the measurements for that would you? I want to do something like that, with one 12
Old Jan 1, 2010 | 04:42 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's partly how the Bazooka type bass tubes work. Install them facing a vertical body panel, and you can "tune" how well they sound by moving them closer or farther away from that vertical panel.
Old Jan 1, 2010 | 05:57 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
It doesn't matter. It's a sub.
Old Jan 19, 2010 | 04:39 PM
mmyers_417's Avatar
Car: 88 formula; 06 cobalt ss
Engine: 305 tpi; 2.4 ecotec
Transmission: WC T-5; F23
Axle/Gears: 3.45 posi; 3.84
i talked to a car audio installer about this when i had my first firebird and put my system in he said that when their angled toward the window the sound will bounce off of it and make it sound louder than if it was just facing u
Old Jan 19, 2010 | 05:05 PM
Car: 1986 Trans Am
Engine: 5.0
Ask 10 different installers, get 10 different answers.
Old Jan 19, 2010 | 10:01 PM
Car: 89 IROC
Gotta tell you that makes absolutely no sense. The only thing it will do is distort the sound.
Old Jan 20, 2010 | 08:18 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
The theory behind aiming the sub back is that the wave length of lower frequencies are longer in length than higher notes. by aiming it back and up, you're giving the wave more time to develop before it reaches your ear. Its more noticable in hatchbacks because there's no divider between your sub and your ears. It won't make a huge difference in cars (since you're not picking up much distance), but every little bit helps.
Not the greatest example necessarily about this topic, but a good start:
http://www.school-for-champions.com/...requencies.htm
Old Jan 21, 2010 | 04:19 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
looks superrrr clean love it
Old Jan 21, 2010 | 07:39 PM
Car: 1991 Camaro RS
Thanks! That's what I was going for!
NORTz89
May 20, 2020 03:51 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
fasteddi
Sep 2, 2015 10:29 AM
sailtexas186548
Aug 26, 2015 03:32 PM
