UQ7 amp
UQ7 amp
I've had a couple sets of UQ7 hardware, and I've sold a few. Today I came across this box that I'm almost positive is a UQ7 amp, BUT it doesn't have the mounting bracket and I'm pretty sure I had two amps at one time, and I've got a pic with two amps and this one doesn't match the ones in the pics.
The case is identical, it's got the same punched holes, and it's the same size, but this one has a tag with a bar code and a part number. The two in the pic I've got don't have the label. I'm thinking this one might be from a Grand Prix STE, or a Fiero, but it looks like it's probably the exact same amp as used in the Firebirds. I'm not sure that the wire pin out's are the same either. It's a 15 pin plug that looks just like the Firebird plug.
Does anyone know the part number of the original UQ7 amps? This one says 16149072. What's it out of? I'm looking to sell this last amp, and my last gain slider switch. I just don't want to sell it as a Firebird amp if it's not.
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: UQ7 amp
i have three of these things laying around, and only one had the original p/n sticker. It is 16040752.
BTW, you ain't got a set of the performance sound subs laying around, do you?
Re: UQ7 amp
No, I sold pretty much everything else I had a couple (4?) years ago. Even then I only had one so-so sub out of a Fiero. I parted two UQ7 cars, only one had the enclosures and the subs were long gone.
Car: 89 Iroc Convertible
Re: UQ7 amp
I just pulled one yesterday from an 86 T/A.Part number on the amp is 16040752
raymondandretti
Sep 27, 2015 06:43 PM
