Removing stock head unit
Old Mar 11, 2010 | 01:13 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I need to remove the original stereo from the car and after removing the surrounding plastic and the 4 screws holding the cassette player in, I couldn't get it to come out. Am I missing something here?
Thanks.
Old Mar 11, 2010 | 04:34 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: Removing stock head unit
should only be that... depending on it aged contact surfaces seem to fuse, they jus require a little light prying
Old Mar 11, 2010 | 04:39 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
if u have taken the 4 bolts off of it already then it should just pull straight out and be able to be unplugged. maybe try sticking a flat blade in between the 2 and give it a little wiggle.
Old Mar 12, 2010 | 11:57 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I will try it again, but i was giving it some serrious force yesterday and it was refusing to come out!
Old Mar 12, 2010 | 02:35 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
might it be stuck with the bottom portion of the ac control boX?
Old Mar 13, 2010 | 11:46 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Could be. I tried unscrewing that but couldn't pull it out fully either. I'll look at it again tomorrow and let you know how I get on.
Thanks.
Old Mar 15, 2010 | 10:19 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Stock radio has a plastic or nylon stud on the back that fits through a hole in a metal cross brace in the radio pod (for stability of the radio and maybe alignment). It may be hanging up on that brace. You might get to it by pulling out the HVAC controls and reaching over top of the radio.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
ZsTransAm
Aug 11, 2015 07:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
