Relocated Battery and Subwoofer
Old Mar 14, 2010 | 04:36 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Anyone running a sub in their F-Body with a relocated battery to the trunk? I don't have much space left but do want to run a woofer. Let me know what you got.
Old Mar 15, 2010 | 05:13 AM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
Re: Relocated Battery and Subwoofer
I don't think theres much room in the trunk for a battery, amp, and sub. You'd prolly have to go with an 8" or a 10", with a sealed enclosure definitely.
for an 8" you're looking at about .25 cubic feet, or about 6x6x12
for a 10" it should be a little under 1 cubic foot
and a 12", if you can fit it would be a little over 1 cubit foot.
Those are all estimates of course, you'd need to know the drivers specs to calculate the box. I'm sure some type of shallow mount sub would fit great also, just for the fact that they usually require smaller box dimensions.
Old Mar 15, 2010 | 07:20 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I put my second battery in the space under the driver side storage compartment. It doesn't fit through the opening, so the plastics were removed and a bracket built, battery installed and plastics reinstalled.
There was plenty of room for a 12" woofer and amp install in the well.
Old Mar 15, 2010 | 12:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Al that looks good man, really good. I wanted to do that but unfortuntely have an amp mounted where your battery is and an amp where the spare used to be. My battery is in the well and it will be tight for a 10" requireing little airspace.
Old Mar 15, 2010 | 01:15 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
well you always can do this ( or somthing like it with some glass work to make it look like it fits and not outta place ) http://www.mobileaudioguy.com/photos...b+box+_13_.jpg
Old Mar 15, 2010 | 04:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
That's a good idea. I could move the amp that's behind there and build some sort of rack/cover plate for the amps in the well. I'm trying to keep my amps hidden if I can.
Old Mar 15, 2010 | 05:41 PM
Al Hasse's Avatar
Mine actually is hidden. The picture abouve doesn't have the cover over the sub & amp. with the cover on, everything looks flush to the cargo deck, just like the stock hinged cover would look.
Old Mar 15, 2010 | 08:53 PM
Brad5117's Avatar
is there any place i can get the cover for the hatch area i love that look
Old Mar 15, 2010 | 10:01 PM
Al Hasse's Avatar
That cover was fabricated from expanded metal welded to a 1/2 square stock frame and covered with acoustic carpet (sub-box type carpet).
Old Mar 19, 2010 | 09:03 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Pick up a BMR battery trunk mount bracket. You should be able to fit the battery and amp in the same area where the spare tire should be.
Then you could put the sub in the bottom of the trunk area.
Then again.....AL's install is VERY NICE
Amp Install
BMR Bracket
Sub in bottom of trunk
Old Mar 21, 2010 | 11:59 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
You can see where i put my sub and amp after getting rid of the spare tire here:
https://www.thirdgen.org/forums/car-...-tire-sub.html
Old Mar 22, 2010 | 12:07 AM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
I have my subs under my seat and they don't get hot
TG Goose I see where you have your amp
Doesn't that amp get hot?
Old Apr 4, 2010 | 11:51 AM
TG Goose's Avatar
Engine: 355 SD TPI
I havent noticed it getting hot. I'm going to build a small metal bracket/shelf to lift the amp off the sub box to allow for air to flow underneath the amp in the future, but for now, it hasnt been a problem.
Old Apr 14, 2010 | 12:14 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
here is where I put mine; https://www.thirdgen.org/forums/car-...lly-built.html
Old Dec 4, 2011 | 08:59 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
any more guys?
Old Dec 4, 2011 | 09:05 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Some nice set ups.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
