Amp question
Old Mar 24, 2010 | 09:47 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Amp question
Hi eveyone, I have a sony Xplod 600 watt 4 channel amp powering my dash 4x6s, and my 6x9s in my sails. My question is, if I take the 4x6s off of my amp, and run them off of the head unit so my amp is only powering 2 channels, will it send more power to my 6x9s? Do I have to do anything to make it do that? thanks
Old Mar 24, 2010 | 09:52 AM
IROC_U's Avatar
Car: 1991 Z28 Camaro
Engine: 355 sbc
Axle/Gears: 4.10
Re: Amp question
To have your amp put out more power to your 6x9s you would have to bridge your amp outputs, which may or may not be safe on your amp, your amp only puts out so much power to each channel so just removing your other speakers will do you know good without bridging
Old Mar 24, 2010 | 05:05 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Amp question
ok, this is the amp I have in my car right now.
link
Is it bridgeable? thanks!
Old Mar 24, 2010 | 10:02 PM
91BirdFreak's Avatar
Re: Amp question
Far as I can find this amp is bridgeable. If you need further assistance please let me know and I can get you a diagram on how to bridge the amp.
Old Mar 24, 2010 | 10:11 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Amp question
That would be awesome if you could! I looked up the manual on the Sony website and it said that is was bridgeable, and I was messing around with it today and but I lost all ambition and didn't want to mess it up.
Old Mar 25, 2010 | 02:49 AM
clomkfly's Avatar
Car: 1982 Z28
Engine: Stock 305 4BBL - New QJet
Axle/Gears: Stock
Re: Amp question
a little more info on what ohm resistance...or stability the amp is would be great...also what ohm rating are the speakers?
ill downgrade for my example... lets say the amp is 4 ohm stable! and each speaker is 8 ohm.... now the amp is bridgeable (assuming). try two channel bridges for starters. sorry to down talk if you do understand what im saying...lol
but yea. a 4 chnl amp...600 watt max at max ohm. speakers prolly max at 200 also and are 8 ohm. i would parallel wire (2 "+"s and 2 "-"s together ) the front two one chnl and same for the back
Old Mar 26, 2010 | 05:09 PM
Pug89's Avatar
Car: 1989 Pontiac GTA
Engine: 5.7 TPI L98
Transmission: 700 R4
Axle/Gears: Not Sure
Re: Amp question
just be careful to see how much power is coming out of the amp when bridged, make sure to check with the rms of the speakers you dont want to throw to much power and blow them.
Old Mar 28, 2010 | 01:32 PM
shawty82's Avatar
Car: 1991 camaro rs
Re: Amp question
i have the same sony amp as you and for some reason im having trouble wiring my rear 6x9 to am could i have some help as of wat you did
Old Mar 28, 2010 | 02:29 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Amp question
well when I had the 4 channels hooked up they were hooked up strait forward, wherever it said to put it on the amp is where I put it. make sure your not crossing your + and -s
Old Mar 28, 2010 | 03:42 PM
shawty82's Avatar
Car: 1991 camaro rs
Re: Amp question
k thnx i did some searching and i think i just did one little thing wrong or something
Old Mar 29, 2010 | 07:34 PM
GND-646's Avatar
Car: 1989 firebird
Engine: 350 tpi
Re: Amp question
i wouldnt do. what 6x9's do you have and how much power can they handle. i have pioneer's that handle up to 300 watts continous each and i hooked a kenwood amp up to them and the amp is only 400 watts into 4 channels and when i turn it up they start to crack and sound like poo poo and you have a bigger amp then i do so i wouldnt do it unless you have some strong 6x9's
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
