84 Swivel Head Unit Replacement??
Old Apr 11, 2010 | 06:40 PM
84chevy703's Avatar
Hello All,
I have an 84 Berlenetta and am trying to replace the current head unit with an aftermarket one...Problem is I have never seen another camaro with the same radio as mine has...it sticks up from a black tube and is a square swivel unit that has am/fm/cassette...any advice on how to change this before I cut it out and fabricate a box? Any wire harness I can use or rewire needed? Thanks for the help!!!!
Jay
Old Apr 11, 2010 | 07:54 PM
cdoyle's Avatar
Re: 84 Swivel Head Unit Replacement??
Originally Posted by 84chevy703
Hello All,
Jay
I would think the easiest way to get an aftermarket installed, is just go to a junkyard and get a center console out of non Berlenetta model. Those should be easy to find.
Then sell your Berlenetta console to someone else, who might need it for restoration. I wouldn't cut it up..
Old Apr 12, 2010 | 03:01 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
what he said. as motivation, you will 100% end up on top when you sell it.
Old Apr 24, 2010 | 01:14 AM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
Putting a standard console into a Berlinetta won't work. It won't line up with the dash properly and you can't use the standard HVAC controls. Without major surgery, it's just gonna look crappy.
There is a box you can mount to the Berlinetta console that holds a regular radio. I have the link on another comp, I'll get it posted in the morning along with a pic of it installed. I really like the way it looks and fits.
I don't know for sure if the wiring is the same as a standard car (allowing the use of pre-made adapters). I'll take a look thru the shop manual and see what I can find.
Old Apr 24, 2010 | 04:59 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've had a different experience with the console and radio. When I bought my Burly they had attached a generic box to the top using large screws ruining the upper plate etc. and it looked like crap. I still need to find a lower radio that works now.
Old Apr 24, 2010 | 07:57 AM
Engine: 5.0 LG4
Here's the link to the housing;
http://www.crutchfield.com/S-7G8jKjR...t.html?tp=2114
and a couple of pics.
Old Apr 24, 2010 | 01:28 PM
Engine: 5.0 LG4
Here's another try;
https://www.thirdgen.org/forums/electronics/517458-berlinetta-radio-housing-has.html
Old Apr 24, 2010 | 01:55 PM
Scorpner's Avatar
Engine: V6, V8
I can't see most of the pics, is this one?
Old Apr 24, 2010 | 02:19 PM
Engine: 5.0 LG4
Yeah. I loaded these pics before (year or two ago), but I'm having trouble linking to them.
Old Apr 24, 2010 | 02:58 PM
Scorpner's Avatar
Engine: V6, V8
I just took the "t" out of the link you posted. I looked at the attachments I made above and compared them and noticed the difference.
In red below:
...attachments/electronics/174340d1237765455t-berlinetta-radio-housing-has-84-radio-housing-02.jpg
Anyways, does that part fit in place of the stock pieces or sit on top of them?
Old Apr 25, 2010 | 07:23 AM
Engine: 5.0 LG4
Sits on top.
Old Apr 25, 2010 | 08:04 AM
Scorpner's Avatar
Engine: V6, V8
It looks better than what I originally had on mine and probably a lot less work than swapping consoles.
Old Apr 25, 2010 | 11:24 AM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Axle/Gears: stock
ive done this too depending on the one you get you are going to have to do some cutting and fitting
Old Nov 24, 2010 | 09:12 AM
IIxDCxII's Avatar
Car: 86 Berlinetta
Engine: 2.8L V-6
Can someone please explain how the underdash kit from crutchfield goes in. For some reason i cannot wrap my head around it. it just doesnt look like it would fit from the pic on the crutchfield website.
Old Jun 18, 2011 | 09:15 PM
1984berlinettas's Avatar
Car: 1984 camaro berlinetta
Axle/Gears: 3.08
the piece flips over and then it sits on the dash and the open part on crutchfeild is facing the floor
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
