Radio Replacement
Car: 1982 Camaro Berlinetta
Engine: LG4
Transmission: One that shifts hella hard
Radio Replacement
What is the DIN size for a radio in an 82 camaro? My radio is pretty much shot, the tape player wont play regular tapes, and when I use my cassette mp3 adapter it spit the tape out when I hit a bump. Would getting it rebuilt be better? Or would replacing it be better?
Re: Radio Replacement
From what I understand, it is a 1.5 DIN size. You should probably just go with what you need/your budget. If you want to be able to play CDs, mp3 players, etc. go for a new head unit. If you don't, maybe look into getting an OEM from a donor car or something.
Car: 1992 Camaro Z28 25th Anniversary
Engine: 350ci w/ TPI
Transmission: 700 R-4 w/ shift kit
yeah it's a 1.5 DIN and it would be cheaper in the long run to just get a new head unit
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
If you want a really awesome instillation adapter check these out.
Car: 1987 Trans Am
Engine: LQ9/L92
yeah, they are spendy, but are well made and look killer. loved mine in my GTP, even went with the option to have the "GTP" logo lit up red.
you've got a supercharged motor under the hood and $100 for a some interior trim's too much?
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Don't know if they still do it but Crutchfield used to give you an install kit including wiring and adapter at no coat when you bought a stereo.
