Main power cable placement
Old May 16, 2010 | 07:38 AM
visago's Avatar
Where did you guys run the main power cable to your distribution block? I have been outside for an hour trying to find a good spot to get the cable from the engine compartment to the inside of the car....any suggestions?
Old May 16, 2010 | 09:59 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Re: Main power cable placement
Drill a hole in the firewall and insulate with a rubber grommet.
Old May 16, 2010 | 12:49 PM
87350IROC's Avatar
Car: 87' IROC
Instead of drilling another hole in your car why not use holes that are already there. I run mine up the passenger side engine bay right by the fender. Then it ducks into the antenna area inside the fender, then it goes through the antenna cable grommet.
Old May 20, 2010 | 09:21 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i too went through near the antenna, but i drilled a hole and used a grommit. is your battery on the driver side or passenger?
Old May 30, 2010 | 03:26 PM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
thats what i did. it takes a little while to get it through ( i used a coat hanger to help)
Caspar
Jun 19, 2016 11:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
