No cd player memory?
Old Jun 1, 2010 | 04:25 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
ive had to decks now and i cant save any settings on either one. am asuming this is a wiring problem. anyone have any ideas on how to fix it?
Old Jun 1, 2010 | 07:37 PM
masonmills's Avatar
Car: 1985 Trans Am
Engine: 305 Carb
Axle/Gears: Borg Warner 3.27
Re: No cd player memory?
there should be i think its a pink wire, thats called ur constant, it has to be hooked up. at least that was my problem
Old Jun 1, 2010 | 10:03 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Yea, it sounds like you dont have a constant wire hooked up.
Old Jun 1, 2010 | 11:57 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
sorry to thread jack but im in the same boat my wiring was F****d up so i people on here told me to run the power off of my fuse panel so i did that but i have no memory. so any help would be great. ive tried wiring diagrams and everything short of taking it somewhere to get it done.
Old Jun 2, 2010 | 12:51 AM
travis401's Avatar
Car: 91 Camaro RS
Stereos need 2 power wires, a constant and a switched. The constant is whats used to store youre settings, the switched is what actually runs the unit when you turn it on.
Old Jun 2, 2010 | 09:46 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Get a meter and look for a 12v constant. Make sure you crank, run and switch off the car while you're testing the wire to make sure it stays hot during the entire cycle.
Old Jun 2, 2010 | 02:00 PM
rscamaro90's Avatar
Car: 90 camaro rs
check the arc(20amp) fuse, that was my problem after having 2 different hu in with no memory.
Old Jun 11, 2010 | 09:56 PM
TNT_Z28's Avatar
thanks ill try to see if its missing its constant power. that makes sence.
Vintageracer
Sep 24, 2017 12:34 PM
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
Linson
Oct 1, 2015 09:50 PM
