$th Gen Door Speaker Swap
Old Jul 28, 2010 | 12:58 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
If 4th gen door speakers are swaped in to the 3rd gen?
are you guys connecting to front 3rdgen speakers?
Any Tips
Old Jul 28, 2010 | 04:34 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: $th Gen Door Speaker Swap
4th gen door speakers are 6.5"
They would fit in the sail panel on a 3rd gen but probably not the dash.
Old Jul 28, 2010 | 08:25 PM
I know but if i wanted to keep them on the door....maybe kick panel- how is the wireing done-
sounds stupid but i am not an audio hook up guy...love great systems i just never really got into installing them.
So if i did the 4th gen swap couldnt i just connect it to the front dash speakers? wiring wise
Old Jul 29, 2010 | 07:11 AM
slow305rs's Avatar
The 3rd gen connector should work with the 4th gen speakers.
But the speakers are physically too big.
Look at the polk audio 4" plate speakers.
Better fit and sound
http://www.woofersetc.com/p6144/DB46...y-Speakers.htm
Old Jul 29, 2010 | 10:43 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
He is trying to swap them into the doors not the dash...
He is wanting to swap them into the doors like the 4th gens since 3rd gens didnt come with them
Hes asking how is wiring will be done
Here my best advice to you If you wanting to keep sail panel/dash speakers
Go buy a 6.5" Comp set with a 1" Tweeter
cut a hole in your door and put speaker in it(Might have to use a small spacer plate or a pod depending on depth of speaker) Put your tweeter on your Pillar Pod on each side
Replace your 6x9s
Get a 4 Channel amp run your 6.5/tweeters/6x9s on a highs/mids amp and have your 4x6 on radio
You wil have good clean clear sound and never have a problem with it
Check out
www.12volt.com for more info
Old Jul 29, 2010 | 03:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if throwing in the 4th gen door panels, i'd reroute the dash speaker wires to the doors and do without the dash speakers. otherwise do a component setup, tweeter in stock dash spot and mid in door, and have the speaker out (from amp or radio) routed to crossover.
Old Jul 29, 2010 | 07:59 PM
Replace your 6x9s
Check out
Done Deal..
Nice reply
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BlackTopKing
Aug 19, 2015 12:13 PM
89lsc
Aug 14, 2015 04:58 PM
