Need help understanding terminology
Old Oct 11, 2010 | 09:21 AM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
I'm in the process of a system upgrade and am hitting road blocks. I need some help understanding a few terms please. When an deck or reciever says say, 200watts, 100watts per channel. Does that mean each channel represents a speaker it can channel its power to?
In the case of a car stereo thats 200 watts, does that mean max 50 watts per speaker?
More questions to come, I just gotta go right now... at work.
Old Oct 12, 2010 | 01:01 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: Need help understanding terminology
The watts listed is total watts. A 200w, 4 channel deck is 50w per speaker. Be careful with those ratings. 200w is peak wattage which is nefarious at best.
Best advice for picking a deck is to ignore the wattage listed and go for the best technical quality you can afford.
Old Oct 12, 2010 | 01:25 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Look for what the deck is putting out as a minimum to each channel and match that to the minimum of your speakers. I buy almost all of my gear online from Crutchfield since I have only had bad luck with the box stores in my area.
Quality components and connectors are the key to an awesome audio system that never distorts at any volume level.
Old Oct 12, 2010 | 12:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the numbers you want to pay attention to are "RMS" - in simplest terms, this is the average power (it gets a lot more technical than this, but for everyday use, we'll stick with this definition). you'll always have companies padding their numbers, so as long as you're close on both ends (speakers to source output) you have nothing to worry about. if there are specific parts you're looking at, post 'em up; someone can help you out
Old Oct 13, 2010 | 09:26 PM
Dark Ember's Avatar
Thanks for the info so far. Someone suggested I post up my projected system components for combatability comments, so here it is. I have another post up with similar links but this is a more updated list.
Currently the plan is to get this stuff, see how it sounds. If it turns out to to be satisfactory, then I will get an amp with 5 channels, and just 1 8" woofer for the rear, and run all the speakers to their maximum.
Will this deck play a CD that has a ton of MP3's burned on it, or will it only play them through the usb port via an Ipod or MP3 player?
Deck:
http://www.buy.com/prod/pioneer-deh-...215636708.html
Dash:
http://www.buy.com/prod/pioneer-ts-a...203922233.html
Sail Panel:
http://www.bestbuy.com/site/Pioneer+...=1218056225571
Old Nov 9, 2010 | 07:49 PM
Tail_Gunner's Avatar
http://www.carstereo.com/help/Articles.cfm
Theres a start..Little fast track here. JBl amps are made or designed by crown...Crown amps are amoung the very best solid states ever built. Now here's a link to reconditioned JBl amps that are under a full warranty... little side note.... amps are like engines not to much more than power generators..but a few like jbl use the right components..
http://stores.ebay.com/Harman-Audio/...=p4634.c0.m322
Keep a eye out for the GTO series...true 4 channel amps 100 per side for maybe 120 ..great amps and nice pricing.
Old Nov 9, 2010 | 11:21 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
the bpx series are crown amps, the gto are straight class a/b amps(deliver power but a bit inefficient)
Old Nov 14, 2010 | 02:36 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
JBL GTO amps are great value for the money. Solid amps that perform very well.
The GTO504 is a great amp to power the front and rear speakers.
http://www.sonicelectronix.com/item_...BL+GTO504.html
Have a look at this article. While you're reading remind yourself that this World Champion car had $250-$300 JBL GTO amps and $130 JBL GTO subs....not too bad.
http://caraudiomag.com/articles/sq-champ-lexus-es300
Jorlain
Oct 8, 2015 01:57 AM
Crall13
Jul 21, 2005 01:02 AM
wiggy'sIROC
Mar 31, 2001 03:23 PM
