How would a single 12" type R sound?
Old Nov 5, 2010 | 02:25 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
SO ive got this 12" type R sub chilling in my living room, some guy came into work and insisted that it was blown and sounded like crap, and that he wanted a W6 from JL, I tried telling him its not blown but apparently an audio installer doesnt know how a blown sub sounds and how a good sub SHOULD sound like.... in any case i pulled his type R, shaved the box out a bit for his W6 and sent him on his way, on my way to toss his old sub i noticed that the positive wire for the second voicecoil came un soldered so i soldered it back in place, hooked it up and its hitting hard like it should free stuff whoo!
Now today i built a dual chambered triple ported box for our showroom floor, i was just tinkering since i havent done much porting so i was winging it, after finishing it up carpeting it and cleaning it i plugged it into the first sound room which is our entry level one, being a W1 i figured itd be pretty lame, i was pretty suprised what 3 3" ports did because this thing hit harder than our W6's in room 3!
Now to the point im thinking of making a single ported box for the camaro with this type R given my experience today, and the fact that its just sitting around, can anyone give me an idea of how hard it will hit in a ported box? Im not sure how ill set it up yet if i wanna do a dual chamber triple port like i did today but i know that the type-r's pack a mean punch, and seeing what one of our crappiest subs did with some simple porting im curious....
I was thinking i could do a single for now and just make provisions to put a second one in later if im not happy enough, make the chambers identical and have a port coming from each one to a single port in the center, that way i could just cut the hole for the other 12 and another terminal cup etc etc
any experience with the type R in our cars guys?? Im gettin pretty ancy i wanna hear it lol but i want the end result to be worth the work
Old Nov 5, 2010 | 07:19 AM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Re: How would a single 12" type R sound?
It will sound great. When I was in High school I had 2 Type Rs and they sounded great
Old Nov 5, 2010 | 09:46 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had a single 12" type-r in my last third gen and was very happy with the output in a sealed box. a good box and some good power, its more than most will ever need.
Old Nov 5, 2010 | 10:13 AM
-srs-'s Avatar
Car: 1991 Z28 Vert
I'm a Type-R fan.
Old Nov 5, 2010 | 11:21 AM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
I dont have any expeirence with these in are cars, but i built a single 10 ported box in my civic and gave it roughly 500 rms watts at 14 vdc and it was amazing. I can only imagine in our cars. They have pretty decent sound quality as well, not like a dub 7 or imagine dynamics idmax , which i have all of these. 1 ported tpye r 12 with the right box and right power in our car will be great. GO for it . How much power you gonna give it
Old Nov 5, 2010 | 11:22 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Im a newer type r fan, Not the old ones with the older style surround
Old Nov 5, 2010 | 12:52 PM
Engine: 5.0 TBI
the older type r subs may not be as good now but they were the best back in their day
Old Nov 5, 2010 | 02:39 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
I don't know how you guys had such luck with one of these a while back i bought a 10" alpine type r and put it in a sealed box. The output has horrible, it sounded nice but it couldn't even move my rear view mirror at all. I have owned a lot of subs and i gotta say this one is the worst.
Old Nov 5, 2010 | 04:11 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
10inch sub+sealed box+ low power= low flex, what did you expect outta it
Old Nov 5, 2010 | 04:21 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Im not an idiot, im giving it 500rms. It has a lot of excursion but just not a lot of output. I know my car audio.
Old Nov 6, 2010 | 04:06 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
thats not alot of power, and again a ten has very little cone area, and you are limiting its output by having it in a sealed box
Old Nov 6, 2010 | 05:22 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Sounds like you got a bad sub...it happens.
500 watts IS more than enough power to shake the mirrors.
Old Nov 7, 2010 | 02:45 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
500 is more than enough power lol my experience with the type R's is that they gotta be ported, no questions asked its a must or youre dropping all the money for nothing, i can get a dub 1 to shake our sound room no problems, and a sealed type R can barely come close, i dont really sell a customer a type R in a sealed enclosure like ever lol
im probably gonna go ahead on this, just for kicks plus i still gotta pick up an amp that will be decent for it, im thinking of going with the PDX5 so i can also power my polks my biggest concern is going to be port noise, if its going in a trunk ports are your best friend cuz youre not gonna hear the port noise but if its firing up towards the hatch its kinda making me sketch, then again the bass it will put out should drown it out combines with amped polks
Old Nov 7, 2010 | 01:29 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Completly agree'd but i do not agree with your amp selection. 300 x1 seems alittle low for a type r even if its ported they can take some power but im not a fan of 5 channel amps soo. When u get done you have to take some pictures of your box.
Old Nov 7, 2010 | 01:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
im not looking for retarded bass and i figure the port will make up for the power lol
92firebirdguy
Sep 1, 2016 07:53 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
84redta
Sep 19, 2015 09:58 AM
ericjon262
Sep 11, 2015 06:07 PM
Hello, Michael
Sep 11, 2015 01:10 PM
