Subwoofer enclosure cubic feet
Old Nov 17, 2010 | 01:44 PM
Carpaholic's Avatar
Car: 88' Iroc
Engine: 5.7 liter
Axle/Gears: 2.77 posi
http://www.sonicelectronix.com/item_...00+SINGLE.html
I bought this subwoofer, along with an amp, from a coworker fairly cheap.
The problem I'm running into is that I've read about the minimum and maximum of volume needed for the box varies by each subwoofer. I can't find any information on this particular subwoofer probably since it came in its own enclosure.
So, if i use the cubic feet of the dimensions of the box its about 1.8 cubic feet. I'm assuming this is the volume of my enclosure I should shoot for. Is there a "safe" range I can play with when it comes to a 12 inch subwoofer?
Also, what would be the downsides of a box too small or one too big ?
Old Nov 17, 2010 | 02:49 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Subwoofer enclosure cubic feet
if you're staying sealed, you can be "close enough" without issue. bear in mind too, the specifications are taking into account the outer dimensions - its a bit smaller in there from the thickness of the material (you lose between 1 - 1.5" all around depending on if they used .5" or .75" material)
a typical (and very rough estimate) 12" will work with about 1 - 1.5 cu ft of air space in a sealed setup
Old Nov 18, 2010 | 12:02 AM
Carpaholic's Avatar
Car: 88' Iroc
Engine: 5.7 liter
Thanks for the information Dan.
Old Nov 18, 2010 | 06:21 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You can call Blau as well to get the exact specs. Also if you don't get the deep sound you want, try adding some fill to the box (make the woofer think it's in a bigger box).
1(800)-950-BLAU [2528]
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
ironbmt
Sep 27, 2015 06:00 AM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
84 TA NV
Sep 6, 2015 08:02 PM
