Crappy wiring
Old Nov 26, 2010 | 11:33 PM
skolland1018's Avatar
Car: 88' sport coupe camaro
Engine: 5.0l v8
Crappy wiring
the wiring for my camaro speakers are really bad would it be hard to change them?
Old Nov 27, 2010 | 12:15 AM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Re: Crappy wiring
not really so long as you are comfortable with wiring and taking most of your interior out to run wires back to the 6x9s. dash wouldn't be as hard though.
Old Nov 27, 2010 | 11:29 PM
Carpaholic's Avatar
Car: 88' Iroc
Engine: 5.7 liter
Axle/Gears: 2.77 posi
Re: Crappy wiring
I just replaced all my speaker wire this past Tuesday and it was the first time I ever tried this as well. It was really easy.
You only need to remove the bolts on the underside lip of the dash pad and four screws in the middle top. The dash slides right out. Those other bolts under there hold in the speaker brackets and also the AC Ducts. You'll see whats what when you get the dash off. The bolt just above the steering column is a pain if you don't have a small nut driver to get in there. I just used the bit and a wrench for it.
Watch how the wires are routed through the dash when you remove the original ones. Getting the front left speaker wire routed down behind the radio took a few attempts. Its not too bad.
For the 6x9's I only had to remove the trim (4 screws) just below the door. Its the one stamped Body by Fisher w/ the carriage on it. You'll have to pop off the cover over the seatbelt thingy to get the trim off. I also had to remove the kick panels which should just be one screw and they pull right out. On the right one, be careful of the light there if you have one.
I also removed some black piece that should be about the same height as the 6x9's in the door jam area. It only has one screw I think and it comes off. If you remove this, you can pull on the molding at the floor a bit and work the wire through. I have pretty big hands and had no problem with this. It'll help to remove the speakers in the sail panel even if you are just rewiring them. I'm sure you know that, though.
I ran my wire from the 6x9's through along the body below the carpet up the where your feet go, hung a left, and right behind the radio. Take a right for the drivers side
It took me about 3 hours taking my time, breaks, and talking to the neighbors. You really don't have to take that much apart, either.
Best advice is to go slow, keep your bolts in a safe place, and tack on an extra few feet of wire for possible mistakes in length estimates or wiring mishaps.
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
bryan623
Aug 10, 2015 11:33 AM
