Constant 12V Power
Old Dec 30, 2010 | 08:55 PM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
Constant 12V Power
I have a 92 RS which my orange constant wire is not giving off any power. When I take the ignition wire and hook it up with the yellow wire from the radio which also has the Orange wire hooked up (constant) the head unit works. When I turn the car off the presets get lost because there is no power coming from the constant wire. I checked the radio fuse on the drivers side and it's fine. Is there another fuse that could be blown? The radio is brand new and works fine. It's a kenwood brand new head unit. Is there another fuse box under the hood?
Any response will help. Thanks..
Old Dec 30, 2010 | 10:37 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Constant 12V Power
Orange wire should go to the ACC fuse. Same fuse as the dome light, cigarette lighter, hatch release, door locks, power mirrors, horn relay, among others. If that fuse is out, check the cigarette lighter socket as it's the most prone to short out and blow that fuse.
Old Dec 30, 2010 | 11:42 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
I tested the cigarette lighter before I put in the stereo. And the dome light works. But I will check the ACC fuse as well. What are my other options? Could the wire be bad?
Old Dec 31, 2010 | 11:13 AM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
have you done any other type of dash work that could have ruined the wire? other then the fuse the only thing is a damaged wire
Old Dec 31, 2010 | 01:18 PM
Al Hasse's Avatar
From the fuse block, that orange wire goes to a factory splice and branches about 9 different places to power all of the accessories. The splice should be behind the right side of the instrument cluster. Should be a lot of tape wrapping a crimp connection.
Old Dec 31, 2010 | 05:24 PM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Thanks for you time guys. I fixed the problem today. It was the 20A ARC fuse under the steering wheel. I replaced it and it works. (Thank god for the haynes manual)
89GTAOz
May 16, 2020 09:31 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
ZsTransAm
Aug 11, 2015 07:30 PM
apie2546
Aug 8, 2015 07:12 AM
