Power antenna motor brushes - do you know of any other gm cars with same ones inside?
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
So I just spent $40 for a new plastic mast and it resolved the issue of the never-stopping motor. Unfortunately during reassembly, I noticed one of the brushes is completely worn out, to the point that the brush pad itself is gone.
So I can go find a broken antenna at the junk yard but I am wondering if anyone knows of a particular (and hopefully common) vehicle that had the same brush/switch assembly inside.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Power antenna motor brushes - do you know of any other gm cars with same ones ins
Any electric motor rewinder should be able to give you a brush that will work.
Iroc8t8
08-26-2015 08:14 AM
