Stock Radio Swap
Stock Radio Swap
Hey Everyone, I am brand new to Camaros. I just bought an 86' 305 as an extra car to drive whenever. It has a stock Delco cassette player that seems to be shorting out on occasion. It fades in and out from the left side to the right and then from the back to the front. Always in random order. It seems if one of the speakers goes out I can either press on the front of the radio or "tap" the side of the console and it kicks back in. Long story short, I assume it's either bad wiring or bad radio unit. My brother has his stock radio from a 94' Firebird that looks identical in size. However, when I try to plug in the, what I assume is a, antenna plug is just a bit too thick to fit in the Firebird unit. Otherwise it looks like the others plugs will match up. Any suggestions? I am relatively new to radio installs. I know matching up colors is not always correct, but I have no other forms of manuals or paperwork to show what is what. Aside from having Best Buy install a separate aftermarket unit, I would like to just save the money and use the Firebird one. Do I need a new wiring harness or am I safe since they are both OEM parts? Thanks in advance.
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Stock Radio Swap
His is from a 4th gen bird, unless it looks exactly the same, don't count on it being wired the same cause it probably isn't, even if they look the same you should check for a part # to be sure, that being said what you need to do is find a wiring diagram for each radio, as for the antenna, I am pretty sure its a universally standard size(though don't quote me on that).
Engine: 3.8, 3.4
Also, chances are someone on the boards has a stock radio they would let go for cheap.
I have mine still after I went aftermarket, but mine is just a radio, not even cassette, the original owner of my car was...odd, bugger sprung for the t-tops which costed more than a v8(and 10% of the car's base cost), as well as AC, and a 3 piece spoiler, but yet got the cheap crap basic radio and a 2.8, though I guess he didn't stick with the duke at least, lol. But you would think all the t-tops cars would be like optioned out for how much that particular option was, seems like the kinda thing only the people with money to kick around would've got.
You're right. I meant it's about the same size dimension wise, but looks completely different. I thought the antenna plug would be universal. But when you're trying to save money it seems like noting every goes right. I tried a couple of times to put the antenna plug but I'm afraid I would have to jam it in and you would think it just slides in. I'll look for a wiring diagram, but if I were to get another radio I may just look around the junkyards to find one. I am sure there are plenty of third gens out there. I would say that previous owner was pretty odd for making those choices. You never know. I had an 89 firebird that had t-tops that leaked like a waterfall. Luckily this Z28 that I just picked up is sealed pretty tight.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
try to get a radio from 88 or earlier. the wiring harness changed in 89, and in 90 they went to yellow letters, which makes my 89 a very difficult year to find a radio for
you can wire a later radio to work in an ealier car, but you need a wiring diagram to determine which wires to connect. it's just not plug and play
Engine: 3.8, 3.4
Yeah my tops don't leak, I thought they did, but its actually my door seal where it meets the window, its cracked in the corner, but weatherstripping is stupid expensive, seriously someone explain to me why it costs more than tires...and I have bigger priorities, plus my driverside floorpan is ****ed already anyways.
Oh, and as for the antenna, you could just splice the other plug size onto your wire lead, that's what I would do, I'm getting kind of used to making things work that weren't intended to work together due to my budget constraints, lol....
I feel your pain with the weatherstripping. I had a 78 Bronco that we had to scope out junkyards to find a truck cap. Once we found it we had to purchase weatherstripping and went with the marine based stripping. It worked just fine. I would do that splice work but the plug is still being used on my brother's new radio. Since it's not my primary car, I'll have to look at some more junkyards to piece the radio together. I hope it's not the wiring and just a bad radio unit. Thank you 58mark for the wiring harness tip.
Car: 89 Iroc Convertible
The antenna connector changed sizes I believe in 1989 so you would need an adaptor.I got mine from walmart as I have a mid 90`s buick cd player in my 86 Iroc
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
As for the antenna fitment issue, this should solve your problem. It adapts from the large Motorola jack to the mini GM plug. As mentioned above, Walmart also carries these.
http://www.amazon.com/dp/B00009UHJX/...X&linkCode=asn
Honestly I would just go get a cheap aftermarket radio I got a $300 floor model Pioneer with MP3 plug in that was a floor model from Best Buy for $79.00. That way if you want to upgrade speakers or run a sub you have all the preouts in the back of deck already for RCA's.
Hope that helps but about your radio problem it sounds like a bad unit and i used to have a car that did the same thing and went away with aftermarket deck.
It is a different wiring harness, but adapters are available
I personally can't stand the way aftermarket radios look, except for the rare 1.5 DIN aftermarkets, and the 2.0 units that some people make fit
I'll probably end up looking for an aftermarket one then with the mp3 port. I want to keep with the vintage look, I agree with you Mark. But if it's going to be around the same price, I may just lean towards the aftermarket if I cannot locate an original in the junkyards.
If price is not an option they make factory radio's with the MP3 port built into it. Totally custom and pretty cool but on ebay they wanted a few hundred bucks for them. Of course they are refurbished with all new buttons and lights which make it nice if your trying to keep it original but too rich for my blood. I like aftermarket better but just an fyi there are other options
Engine: 3.8, 3.4
Come to think of it, if hes really set on keeping it stock, he could probably have it rebuilt for less than an all new unit would cost, or fixed at least.
db057
Aug 11, 2015 10:11 PM
