Different type of sub boxes
Old Jul 26, 2011 | 08:32 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
What are some other boxes that will fit 12" subs that i can make for my car other than the one that takes up the whole well in the trunk. Just lookin for some other options.
Old Jul 26, 2011 | 09:44 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Different type of sub boxes
spx sub box. i run it, look at my albums for pictures
Old Jul 27, 2011 | 07:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I simply made a shelf across the back, down in the well - I have 10's installed, but 12's will fit (I have 12" covers over my 10" subs). http://i287.photobucket.com/albums/l...2RS/hatch1.jpg
Old Jul 27, 2011 | 07:20 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Your box is dependent on mounting depth and cubic volume required for the sub you pick.
Old Jul 27, 2011 | 08:15 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Camaronewbie, did you make a box for your subs there or is it just a peice of wood going across the back. If so does it sound good. I think i saw your post that you only had 1 sub under there and the other one is just a cover.
Old Jul 28, 2011 | 11:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
it is always best to build the box to the sub's specifications, as you'll get better and more accurate output. i built my last one to only take up the bottom half of the well and it worked very well. a bit of a tight fit for a 12", but it is doable.
Old Jul 28, 2011 | 12:27 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
When i get my subs on saturday or sunday im gonna experiment with them and different spots i can put them.
Old Jul 28, 2011 | 02:32 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
best to make a box to fit the subs specs
I have dual bazooka 10's that are facing the floor and they sound great.
Old Jul 28, 2011 | 03:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I had a friend in high school that did this. Just a wood "flap", that was hinged towards the front of the car. Two 12's in his. Worked excellent, very powerful. Likely not a very tight/crisp response - but that's the price you pay I suppose.
Other people have done a fiberglass box in the spare tire well, or perhaps a shallow box over the gas tank. Not a ton of space in these cars either way
Old Jul 28, 2011 | 04:04 PM
Engine: 383 SBC
There is 7 cubic feet+ in the hatch area. It's just most people aren't willing to go to that extreme. Like I said in my first post we can all throw around ideas all day long but they need to be designed to the subs. Some subs fit some don't and then you need to figure cubic volume you need. Most brands give you measurements easiest way is just make cardboard mockup of the subs you want and try different positions.
Old Aug 20, 2011 | 04:21 AM
83 Crossfire TA's Avatar
details? Is that a bandpass?
Old Aug 20, 2011 | 11:35 AM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
No its just a ported box and it had roughly .8 cu ft per sub but it wasn't sounding good for the style of music I like so I rebuilt the box for a sealed and its great. I decided to point the subs down so that I could still put groceries in the back and since I put feet on the bottom the subs don't hit the floor when they kick. Planning on moving the amps into the spare tire area for a fully stealthed system.
$750 L98
Feb 1, 2025 02:25 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
tattmann
Sep 27, 2015 05:20 PM
Dragonsys
Sep 25, 2015 03:51 PM
Hello, Michael
Sep 11, 2015 01:10 PM
