Subs cutting out
Old Sep 1, 2011 | 01:06 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Subs cutting out
So just got a rockford fosgate punch p500-2 channel amp and two 10" mtx's got everything wired then turned the stereo on sounds great till i turn it up then the subs cut in and out how do i fix this?
Old Sep 1, 2011 | 01:25 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: Subs cutting out
Is the amp going into protection? Do your headlights also cut off when the subs stop?
Old Sep 1, 2011 | 02:50 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
everything works fine when they do cut out but if i have the volume or the subs turned down then its fine but once i turn them up it cuts out
Old Sep 1, 2011 | 03:12 PM
Spike_Akers's Avatar
Car: 83 camaro z28, 92 xj
Engine: 305 Crossfire (lu5)
Axle/Gears: richmond gear 3.73:1
make sure its grounded good. it sounds like the amp is going into protection, to find out watch the amp as the music plays, it should have a light on the side that tells you if its going into protection mode... after you make sure its grounded well, if it still does it then up the size of your wiring. may need to go to 4/0 awg..
EDIT: after thinking about it... how do you have them wired? heres some ways RF recommends you wire them.. http://www.rockfordfosgate.com/produ...9&locale=en_US click on the WiringWizard after you open the page, it will show you a bunch of wiring diagrams.. they're all bridged and work at the correct impedance for that amp... i have a feeling thats going to be your problem right there...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
