How do I get my deck to fit?
Old Sep 1, 2011 | 06:10 PM
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I had my deck working but my mount wasn't attached yet but with the mount on it sits too far out. I've read things about people cutting the vent or moving it to make their deck fit but I'm not sure about it.
Old Sep 1, 2011 | 09:00 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Re: How do I get my deck to fit?
No need to cut. Un fasten the HVAC controls and the 10 MM bolt above the HVAC and the one 10mm bolt on the floor and remove the radio pod. Then you should see 4 screws that when taken out will remove the HVAC ducts in the pod. I just did this.
Uploaded with ImageShack.us
Old Sep 1, 2011 | 10:40 PM
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
Wouldn't that make the heater/ac useless?
Old Sep 2, 2011 | 10:00 PM
cdoyle's Avatar
I took my pod out awhile ago, but I didn't have to remove the ducts. I'm trying to remember how it mounts, but I do know I still have my heat ducts in place.
Old Sep 3, 2011 | 06:41 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
depending on the deck, some need to have the rear metal bracket support bracket removed, others require some modding to the ducts.
Old Sep 3, 2011 | 03:55 PM
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I removed the bracket and I had to use a heat gun to push the vents back further. The deck is flush now and the vents still work fine.
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
