New system
Old Oct 6, 2011 | 05:16 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
New system
Well UPS just dropped off all equipment for the car, I am going to try and wire it all in this weekend.
Attached Thumbnails New system-101_0183-1280x960-.jpg   New system-101_0182-1280x960-.jpg
Old Oct 7, 2011 | 07:56 PM
91 Droptop's Avatar
Re: New system
What would be the best guage wire to run power to the amp? it has been a long time since I put a system in a car
Old Oct 7, 2011 | 11:27 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: New system
What size fuse does the amp have? That will determine what size wire to use. There's a nice chart for that on this site...
http://www.powerstream.com/Wire_Size.htm
Old Oct 8, 2011 | 12:11 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Re: New system
If it has between 100-400,run 8 or 16 gauge
If it has over that amount,run 4 Gauge. IMO,4 is the best for any system.
Old Oct 8, 2011 | 05:16 PM
91 Droptop's Avatar
Re: New system
I just found out that I can get a free extended warranty on my amp if I use the Rockford-Fosgate amp instalation kit, just found one on Amazon for $98. It has everything I need including wiring for a second amp, so if I ever decide to put in a sub and amp it will be ready to go. Thanks for the advice guys
Old Oct 11, 2011 | 07:29 PM
91 Droptop's Avatar
Re: New system
Well since I am missing a lot of my trunk trim parts I decided to just fab out the entire trunk, goona try and go West Coast Customs clean and neat
Old Oct 11, 2011 | 09:04 PM
Da Spudro's Avatar
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Re: New system
since i have looked all over the car audio section and have yet to find pictures of someones box in a vert i decided i was going to do my own custom glassing which would allow me to use my trunk still.... i made a stencil to glass the side storage areas of my vert and discovered after i made the stencil that it looked awsome and would be killer when glassed..... then i scratched my head and thought..... once i build it how am i getting it IN the car..... and if i glass it in the car how will i get it back out. so i scratched the original idea of glassing the whole box to form fit the back side areas... instead i plan on making a generic MDF box which fits in the side areas and then creating a glass facade out of the stencils i made. it'll be a two peice setup and i'll have to figure out how to remove the rattles, but it should work out nice. i'd be interested to see how your box turns out and what you do so post some pics when your finished.
Old Oct 12, 2011 | 02:19 PM
91 Droptop's Avatar
Re: New system
Mine will be in three parts, but I am going to run the carpet so that it looks like one when you look in. I have ideas just need to get them on paper. I want to kind of hinge it so I can swing the sides open to get behind. I may need to build an actual box that fits the entire trunk so it stays solid and rattle free. I am sur I will need lots of head scratching time lol
Old Nov 28, 2011 | 11:20 AM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
Re: New system
any luck. im on my vert and needing pics.
Old Nov 28, 2011 | 04:30 PM
91 Droptop's Avatar
Re: New system
I have not even gotten back to this yet, I decided to focus on the drivetrain and suspension. I will get there after the holidays I hope
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
