step by step for rear speaker(6x9) instal
Old Dec 2, 2011 | 09:47 PM
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Looking for some guidance for the speaker swap as far as which trim pannels or the rear seat ect. need to be removed for the instalation.
Old Dec 3, 2011 | 09:13 AM
larochelle's Avatar
Car: '84 Z-28
Engine: 355
Transmission: 4L60
Re: step by step for rear speaker(6x9) instal
remove one screw for the hanger hook on the top of the sail trim piece and remove it and you will see the speaker. easy nuff
Old Dec 4, 2011 | 02:57 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Once you remove the sail panel by removing the screw that secures the hook, you will notice the speakers can be removed by removing the 4 screws.
Just make sure the speaker wire doesn't fall down into the hole. I use clothes pin or zip tie and string...just in case.
Changing speakers should take under 15 min per side.
then....it's MILLER TIME.
Shot of my JVC speaker swap in my 87 TA.
http://i209.photobucket.com/albums/b...m/SDC11956.jpg
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
