A single DIN head unit with a .5 DIN EQ stacked?
Old May 26, 2012 | 05:20 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Has anyone ever done it. Can it be done.
Any pictures?
I am thinking about giving it a try to see how it turns out. I could put the EQ below the head unit. The biggest problem I see is getting them to stack.
Any advice.
Old May 26, 2012 | 06:17 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: A single DIN head unit with a .5 DIN EQ stacked?
Sorry, no pics, but yes, it can be done. I used to have a Kenwood eXcelon head unit with .5 DIN Kenwood EQ which contained my sub output. Just need the correct dash kit to mount them up - you can do it with the EQ on top or bottom. At times, I've just used the mounting tabs in the dash kit for the head unit only and used duct tape to secure the EQ to the deck, cheap, but works in a pinch.
Old May 26, 2012 | 10:25 PM
Denn11's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 305
Axle/Gears: 9 Bolt 3.45
Bought the car with it installed as per picture.
Have removed it and put factory cassette back in (with aux input for ipod or other player
Have no info on mounting brackets
Attached Thumbnails A single DIN head unit with a .5 DIN EQ stacked?-img_1068.jpg
Old May 27, 2012 | 09:55 AM
rawley2's Avatar
Thanks guys. Now I feel better giving it a try.
Old Jun 24, 2012 | 06:47 PM
Abubaca's Avatar
heck yeah it can be done! That's oldschool right there! .....back in HS, about every GM carguy I knew had a deck and EQ stacked like that! ....wow....takes me back!
Old Jul 4, 2012 | 10:46 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Ohh yea it is. But still sounds better than anything else on the market. Unless you have a a 7 band built into the head of course
Macchinist
Oct 2, 2015 02:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
ZsTransAm
Aug 11, 2015 07:30 PM
