Fit question - metal on metal?
Old May 31, 2012 | 12:23 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
Just hooked new 4 x 6's up front. They sound great! They dropped down pretty easily, although I'm not too wild about the metal base below the magnet making contact with metal below the dashboard on the left side. Is this a problem?
Old May 31, 2012 | 01:30 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Fit question - metal on metal?
Not a problem.
Just as long as no contact is made with the terminals or tinsel leads, it's fine.
Old May 31, 2012 | 02:19 PM
mav75's Avatar
Car: '89 Trans Am
Thanks, Six_Shooter! Now all I have to do is put the dash back on and hope the left side isn't too high. Crossing my fingers on that one...I'll find out tonight when I get home from work.
Old May 31, 2012 | 07:09 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
If it is too high, get out your dremel and take a little plastic off of the bottom of the grille area. It usually does not take much to get the needed clearance.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
