stereo cutting out?
Old Aug 6, 2012 | 10:45 AM
Aewing90's Avatar
Car: 1990 camaro iroc z convertible
stereo cutting out?
I hve put in an aftermarket deck and new speakers in the front and back. Nothing special. I am wandering if i might need a bigger alternator. PLEASE help me out i am looking to put a small sub in the future???
Old Aug 6, 2012 | 11:14 AM
Z28Johnny's Avatar
Re: stereo cutting out?
If you just did a deck and speakers you definitely should not need a new alternator. You would need to add some big amps to your sound system to need an alternator. If it is cutting out I would say you have a loose wire somewhere.
Old Aug 6, 2012 | 12:22 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Does the deck show "protect"?
If so, that probably means that a wire or your speaker terminals are grounding out.
Take a multimeter and set it to continuity. Pull your deck and locate your speaker wires. Place one lead to chassis ground, place the other to the speaker wire (one side at a time). If any continuity is shown to ground, you have found your problem. Check that speaker and possibly replace that length of speaker wire. 90% of the time it's a bad/shorted wire in these older cars.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
jrdturbo
Mar 31, 2016 02:58 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
