are my 84 trans am radio wires correct?
Old Sep 3, 2012 | 12:49 AM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
I bought my 84 trans am with no radio installed in it and the only wires i can find are one blue plug with 4 wires and one small white plug with 2 wires.
neither the factory or aftermarket radio i installed are working, the fuse is good
the factory radio and the wire adapter both have spots for extra plugs, so is my car missing some extra wires or are these all there should be
Old Sep 3, 2012 | 01:25 AM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
Re: are my 84 trans am radio wires correct?
I just finished sorting out my '85. Wiring should be the same.
You're missing two plugs.
It looks like you have the rear speakers only and the main power.
I think if you provide a ground to the black wire on the radio it will play.
The ones your missing should branch out from a bundle that feeds into the console from under the carpet like this.
Here is the wiring list.
1985 Pontiac Firebird Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
And here is where I got this info.
http://www.modifiedlife.com/1985-pon...iring-diagram/
Old Sep 3, 2012 | 01:39 AM
jez3941's Avatar
thank you ill look to see if they are stuffed under the dash or grab some at a junk yard and run them up to the speakers myself
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
ZsTransAm
Aug 11, 2015 07:30 PM
