OEM Radio Don't Work
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
It is the original CD player in mu 1992. It only displays 0:00 and the volume bar works. It does not say "LOC"
Photo of radio.
Any suggestions?
Photo of radio.
Any suggestions?
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
Re: OEM Radio Don't Work
That is very weird, strange, bizarre, and ironic. I've had this identical radio along with 4 other same vintage radios for 6 months. I've been looking for an operational cd mechanism for at a decent price. The going price for a reman unit is $225. Anyway I ran across a 1996 gm radio with the same cd mech that worked. I've tried it in all 5 radios and it works. In fact I have it plugged into your identical radio listening to a classic music cd (that i don't care about in case i screw it up)
Anyway your problem sounds like a bad power switch or a blown fuse. Both the yellow wire and the orange wire have to have 12 volts with the ign on.
Engine: 5.0
Axle/Gears: Posi
Ok, so I am going to take bak what I just said trying to duplicate your problem, noticing that you have 3 zeros and some volume status. Not a blown fuse. Probably not the power switch either. Try unplugging the radio for a few minutes and try it again. If it still does not work, it coud be the display or the cdm module. LMK, I have a couple of good displays and cdms that will work.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
anybody know of a Good Radio Repair shop??
wana get mine fixed..went bad, just from sitting, for 10 years.
Engine: 5.0
Axle/Gears: Posi
Artic,
Chances are that there is very little wrong with the CDM part of the radio. What are the symtems?
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
I have a nearly identical problem with my UU6 radio, it shows time and I can set it, but that's it. The strange thing is that it was working perfectly before when I tested it a few times on the car power (before I had just tested it on the bench), with the AUX input, it was perfect. And then i put back the interior together and now it won't work...
I have tested several aftermarket radios and they work fine.
db057
Aug 11, 2015 10:11 PM
